Interior/Exterior Tail lights for 03
Old Mar 8, 2009 | 10:57 AM
djmini420's Avatar
djmini420
Tail lights for 03
Any1 here got a set of tail lights they want to sell. i broke both of my mine while trying to dechrome. or where i could get a cheap set.. thanks
Old Mar 8, 2009 | 05:51 PM
minjae's Avatar
minjae
they come up in the marketplace every now and again for pretty cheap..sometimes ebay..
there are the aftermarket ones..that arent oem
but i've heard good stuff from them..
Old Mar 9, 2009 | 06:16 AM
buzzsaw's Avatar
buzzsaw
Found this link on our site that may help.
Old Mar 9, 2009 | 06:17 AM
Mike S's Avatar
Mike S
I would just go aftermarket, they are really cheap and are of great quality.
Old Mar 9, 2009 | 11:59 AM
PureWorks's Avatar
PureWorks
O4 factory rears, $100 plus shipping
Old Mar 9, 2009 | 06:50 PM
xnotfunkylex's Avatar
xnotfunkylex
Ebay!
Old Mar 9, 2009 | 06:55 PM
djmini420's Avatar
djmini420
do u guys know if the aftermarket tail lights are any easy opening up.
Old Mar 9, 2009 | 08:18 PM
Malcon's Avatar
Malcon
is pure works offering you 04 tails for $100?
just in case you missed it
Old Mar 9, 2009 | 08:55 PM
djmini420's Avatar
djmini420
ya i know i was just looking at options.. thanks..
Old Mar 9, 2009 | 10:25 PM
4Boogie's Avatar
4Boogie
all throttle no bottle
you should just use a Dremel to cut them open instead of trying to pry them apart. Put them back together with a epoxy that has a needle that mixes the two parts for you.
Old Mar 10, 2009 | 08:42 AM
djmini420's Avatar
djmini420
i used the dremel but it still cracked anyways.. but i only used the dremel to start if off then i used a screw driver. Did u use the dremel around the whole thing? i am gonna get another set and try again. and this time do twice as slow...
Old Mar 10, 2009 | 09:37 AM
4Boogie's Avatar
4Boogie
yeah cut it all the way around. cover the lens with tape first so you dont scratch them or get epoxy on them.
Old Mar 10, 2009 | 10:02 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep - I cut mine all the way around also... I could tell they were gonna crack was I was prying on them, so I just went ahead and cut all the way - quick and easy, really. Just have to clean up the melted plastic from the dremel all the way around.
GREAT tip about taping the lenses to protect against stray epoxy. Of course, that doesn't help when you drop the whole lens into a batch of mixed epoxy like I did.
So good tip on the self-mixing epoxy syringe, also.
Old Mar 10, 2009 | 10:35 AM
djmini420's Avatar
djmini420
Awesome... thanks for the tips... did u spray everything that was chrome inside black?
Old Mar 10, 2009 | 10:43 AM
BlimeyCabrio
Depends on whether you get pre- or post-facelift tails...
Mine are post-facelift tails... so I just had the chrome ring around the perimeter - masked and sprayed it with plastidip.
Old Mar 10, 2009 | 11:11 AM
glnr13's Avatar
glnr13
another option if you have the post facelift tails: you can just remove the chrome with some denatured alcohol, it wipes away to reveal the red lens.
Old Mar 10, 2009 | 05:55 PM
djmini420's Avatar
djmini420
whats post facelift tails?
Old Mar 10, 2009 | 06:14 PM
glnr13's Avatar
glnr13
i dont remember the exact month but it's basically 05-06 hard tops, 05-08 cabrios.
the light is mostly red except for the small white light for reverse. there is no reverse light in the center of the bumper like 02-04 MINIs
Mb460
Aug 20, 2016 10:39 PM
smarsha11
Aug 24, 2015 06:03 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
