Interior/Exterior A few new upgrades
Old Feb 4, 2009 | 10:30 PM
Malcon's Avatar
Malcon
A few new upgrades
I finally finished installing a few upgrades. I got the M7 DFIC, M7 APD, mini eyes, BMW badges, DFIC scoop...
I also received the Forge radiator overflow tank, and power steering tank, but i haven't had a chance to install those yet.. boo
sorry for the dirty car........its winter
and for the wintery spirit...
Old Feb 5, 2009 | 12:00 AM
Some Guy's Avatar
Some Guy
Not sure if I am a fan of the BMW badges. And the engineer in me doesnt like the connectors you used for the OCC (although they are certainly fine for the app and of course look nice). Otherwise though cool deal man, I like it.
Try to avoid using the flash and shoot in the sunlight when you can, it makes things look nicer.
Old Feb 5, 2009 | 06:40 AM
Malcon's Avatar
Malcon
thanks man!
Yeah those were just quick snap shots. I think i was at McDonalds. so i was in a hurry to get back in the car.. it was pretty cold haha
Old Feb 5, 2009 | 07:19 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Nice....looks awesome.
My OEM Intercooler is looking bit "used" up right now. Seems to be developing some sort of whitish film on it, and been getting lots of New England driving stone dings after adding the M7 Extreme bonnet scoop.
Gonna have to do something like this soon as well.
Old Feb 5, 2009 | 11:27 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What size itg filter is that on your Alta CAI?
Old Feb 5, 2009 | 11:47 AM
cartar452's Avatar
cartar452
Nice, now fashion up a rig to spray nitrous on the DFIC.
Old Feb 5, 2009 | 10:41 PM
Malcon's Avatar
Malcon
I'm not sure what size the filter is at the moment. This is the minspeed intake... maybe ask pete at Minspeed.net?
as for the nitrous, I'm working on a setup right now...
anybody need an IC sprayer??
i'm thinking about going with the M7 venom with the 440 injectors....
who knows
Old Feb 5, 2009 | 10:51 PM
D-MAN's Avatar
D-MAN
A nitrous sprayer for the DFIC would be cool, I have been playing with a few ideas... let us know how it goes...
BTW the car looks cool
Old Feb 6, 2009 | 05:48 AM
mini_racer's Avatar
mini_racer
Are you just referring to the fact that they are overkill in term of strength?
They certainly look good to me.
Old Feb 6, 2009 | 05:58 AM
mini_racer's Avatar
mini_racer
BTW, I know you said your car is dirty, but the dark stuff under the moter mount appears to be the hydraulic flud that is supposed to be on the inside of that mount. So, you might want to check that mount cause if it is bleeding, then it is time for a new one. This is a quick warranty fix if you are still covered, and an easy DIY if not. Also, if not in warranty you should consider the TSW aftermarket motor mount replacement, as well as their engine damper (which will limit engine movement and help save the next mount).
Nice mods, looks great, and will better when you can clean it.
Yes, I know it is winter.
Old Feb 6, 2009 | 12:30 PM
Some Guy's Avatar
Some Guy
No, no, no. They are perfectly fine for the app. It's just that those type of connectors have a reputation for not working all that well when they are used in a high stress, critical app (IE oil lines), hence you want to avoid them there. That is why you will never see those on the UCONN SAE car. But for an OCC they look nice and I wouldnt be against using them myself in the same role.
Although I dont specifically know who made those connectors so all my conjecture is of little consequence.
Old Feb 6, 2009 | 08:51 PM
Malcon's Avatar
Malcon
those are Russell lines and fittings.
I figured they looked nice and were better than the cheap rubber hose that came with the cc
Old Feb 6, 2009 | 09:51 PM
mini_racer's Avatar
mini_racer
Got it, thanks. And well the OCC is a very very low pressure application, so I would expect no issues from those connectors. I have seen many just use the cheap rubber hoses with no clamps or connectors at all.
Old Feb 6, 2009 | 09:53 PM
mini_racer's Avatar
mini_racer
BTW, I know you said your car is dirty, but the dark stuff under the moter mount appears to be the hydraulic fluid that is supposed to be on the inside of that mount. So, you might want to check that mount cause if it is bleeding, then it is time for a new one. This is a quick warranty fix if you are still covered, and an easy DIY if not. Also, if not in warranty you should consider the TSW aftermarket motor mount replacement, as well as their engine damper (which will limit engine movement and help save the next mount).
Don't forget to check out that motor mount!
Old Feb 7, 2009 | 07:30 AM
Malcon's Avatar
Malcon
Yeah I'm heading to the dealership this comming tuesday for a full inspection. its past due anyway.
thanks for the heads up!
-Malcon
Old Feb 7, 2009 | 07:42 AM
mini_racer's Avatar
mini_racer
-Malcon
One more thing on that motor mount 'blood'. It cleans up very well with Isopropyl (i.e. Rubbing) Alcohol.
Good Luck
Old Feb 7, 2009 | 07:53 AM
ScottRiqui's Avatar
ScottRiqui
Good Luck
Nice tip - I've been wondering what to use to clean up the goo from where my mount leaked, because so many of the solvents I usually use for similar stains (like 3M adhesive remover) don't play well with the non-clearcoated paint under the hood.
Old Feb 7, 2009 | 10:17 AM
Malcon's Avatar
Malcon
yikes
molala
Oct 2, 2015 01:53 PM
Sep 10, 2015 10:52 AM
Sep 3, 2015 10:29 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
