Interior/Exterior removing plastic on steering wheel spokes
Old Nov 10, 2008 | 07:57 PM
Malcon's Avatar
Malcon
Anybody know how to remove the plastic pieces on the spokes of the steering wheel, and the piece that is on the part of the steering wheel what works the horn??
I would like to paint these but i dont know if there is a trick to getting them off.
thanks!
Old Nov 10, 2008 | 08:06 PM
glnr13's Avatar
glnr13
spoke caps: there are torx screws behind each one of the pieces.
i've never tried to take them off without taking off the horn/airbag and steering wheel. looking at it i dont think you can get them off without removing the horn.
center ring cannot be removed from the airbag/horn assembly
Old Nov 10, 2008 | 09:00 PM
Malcon's Avatar
Malcon
that sucks.
seems like a pretty larg undertaking.
Old Nov 10, 2008 | 09:45 PM
glnr13's Avatar
glnr13
it's not really.
1. disconnect the battery.
2. slide in a long flathead with the flathead horizontal into the 2 "+" slots at the corners of the wheel.
there are springs inside of the wheel holding the horn in place. you're going to push on the springs with the screwdriver.
here it is closed:
this it opened:
slightly pull on the corner of the horn/airbag while you get each side done.
there you go. airbag's off.
Old Nov 11, 2008 | 06:53 AM
Malcon's Avatar
Malcon
oh ok thats awesome.
Thank you so much for the pictures and the little write up!
I owe you one.
Old Nov 11, 2008 | 12:02 PM
glnr13's Avatar
glnr13
no problem.
the +'s are not cut so you'll have to take an exacto knife or razor to it to get thru it. place the airbag metal side down when you put it aside on a no static surface.
post pics when you're done with the paint job
Old Nov 11, 2008 | 01:01 PM
Malcon's Avatar
Malcon
will do. thanks again
Old Nov 11, 2008 | 03:19 PM
chad1140's Avatar
chad1140
Now for someone to make some big bucks and to offer these pieces in chrome. I wouldn't mind letting loose with 150 bucks If I could have these made in chrome. I know that they are offered for the 2 spoke wheels but does anyone know if they are made in the 3 spoke design?
Old Nov 11, 2008 | 03:21 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
For less than $150 you could just take them to any plating company and have your parts chromed...
Old Nov 11, 2008 | 05:35 PM
not-so-rednwhitecooper
But the airbag ring isn't removable, so it will still be silver.
Sounds like it might look kinda dumb to me.
Old Nov 11, 2008 | 05:56 PM
duvinclunk's Avatar
duvinclunk
After the airbag is taken off do you just press it back into place and the springs lock it in? How does that go?
Old Nov 11, 2008 | 05:59 PM
glnr13's Avatar
glnr13
Old Nov 11, 2008 | 06:03 PM
Originally Posted by glnr13
Brilliant bright silver chrome LIKE appearance.
Old Nov 13, 2008 | 08:01 AM
chad1140's Avatar
chad1140
Yeah I have never seen rattle can give the true essense of chrome or even stainless steel for that matter. What company could chrome plastic?
Old Nov 17, 2008 | 05:30 PM
haygood's Avatar
haygood
I think most chrome places do that now. They would know who to send you to anyway.
I wouldn't have the courage to try removing the center ring around the airbag, but I was able to slip a credit card behind the edge all around. So get a piece of nylon sheet (or plastic bag, whatever), cut it into a circle, and stuff the edges up under the ring using the credit card. Do the same from the outside with the piece you cut the circle out of. Just some suggestions. I am hoping to paint mine, once a million other projects are done. I have the lighted multi-function stuff to deal with though, so its going to be interesting (I'm thinking latex mask brushed on and cut out around the buttons, but cutting those circles will be tough).
I think I saw chrome for the non-mfsw three spoke. Maybe on a british site?
Old Nov 24, 2008 | 11:58 AM
chad1140's Avatar
chad1140
Yeah I have looked real hard but haven't found chrome even for the non MFSW, if you could get the Brit site I would appreciate it.
Old Nov 24, 2008 | 12:42 PM
Rally@StanceDesign
Just search locally for a plating company. That's generally all the company does...chrome/gold/copper/etc plating for metal and plastic parts.
Old Dec 26, 2008 | 11:55 AM
minigirl78's Avatar
minigirl78
it's not really.
here it is closed:
this it opened:
I tried doing exactly what you illustrated for about 30 mins and no luck
I'm trying to replace the panels with the mf switches...any idea why I can't seem to get the blasted airbag off the steering wheel?
Thanks!
Old Dec 26, 2008 | 12:06 PM
Fatherdeth's Avatar
Fatherdeth
You're probably not hitting the spring dead on. You should be able to feel the tension remove. Pull up on that side, then go to the other side and repeat. Keep trying, and you'll get it. Just be careful.
Old Dec 26, 2008 | 06:51 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Actually, I felt a 3D domed decal for these parts would work great. Especially since these rings get all dinged up from seat belts all the time. Mine looks like the surface of the moon from previous owner :(
A vinyl decal would be too thin to cover the dings, So I sent an email to Aestethic Creations Inc to see if they would manufacture a 3D ring in colors and chrome to cover it. I Never got a response back .....
Dec 23, 2015 10:36 AM
Powershift
Aug 16, 2015 05:14 PM
skippermini
Aug 12, 2015 10:05 PM
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
