Interior/Exterior Schroth Harness Owners...
Old Oct 20, 2008 | 09:12 PM
yellowbritishrocket's Avatar
yellowbritishrocket
i just got a pair of harnesses from another user but i didnt get the hardware to go with it....has anyone installed these without the included bolts for the rear? what is the size of the bolt/washer/spacer that you used...
any help would be appreciated
Old Oct 20, 2008 | 10:07 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I used the stock bolt and no spacers. My harness came new with no hardware.
Old Oct 20, 2008 | 10:37 PM
Motor On's Avatar
Motor On
yeah if you do it *just* right it with the required bending anyways it *shouldn't* be much of an issue. I'll take a look when the sun comes out tomorrow and see if I cat get a size for you.
Old Oct 20, 2008 | 10:41 PM
Eric_Rowland's Avatar
Eric_Rowland
+1
They call for a special bolt/washer, but I just used the OEM with no detrimental effects.
Then again, I didn't roll it over, either.
Old Oct 20, 2008 | 11:24 PM
yellowbritishrocket
i just installed using the stock bolts and it went it just fine! im about to go give em a test but they went in without an issue
Old Oct 20, 2008 | 11:33 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
See #5 on page 8
http://www.mini-madness.com/pdf_file...%20install.pdf
Old Oct 21, 2008 | 05:15 AM
minimarks's Avatar
minimarks
I also installed with the stock bolts.
Old Oct 21, 2008 | 06:16 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Stock bolts, no issues for me.
Old Oct 21, 2008 | 07:09 AM
STLMINI's Avatar
STLMINI
I'd contact HMS motorsports and get the right hardware. You won't know if another solution will work or not until it's too late. Also, it can't be very expensive.
Old Oct 21, 2008 | 07:26 AM
Bigshot's Avatar
Bigshot
This is what a friend of mine did.....and he got new hardware for a very reasonable price.
Old Oct 24, 2008 | 08:26 PM
Wagnbat's Avatar
Wagnbat
Not just 'stock', the bolts that are already there. Just unscrew them, put the harness in between the factory belts and the bolt, and screw the bolt back in. No spacers or special hardware necessary.
Old Oct 27, 2008 | 07:35 AM
Bigshot's Avatar
Bigshot
I wouldn't suggest that as it shortens the bolt length in the body. To what effect I am not sure, but I wouldn't take a chance on it not performing like it was designed to.
Old Feb 24, 2009 | 06:25 AM
davavd's Avatar
davavd
I just ordered the bolt, spacer, & washer from HMS Motorsport. They were very cordial and helpful and it cost $6. I'm thinking there had to be a reason Schroth didn't use the stock piece.
Old Feb 24, 2009 | 06:35 AM
Big Daddy's Avatar
Big Daddy
Originally Posted by Eric_Rowland
+1
I used the stock bolt and washer and did roll it over. It worked just fine.
Old Jun 28, 2010 | 10:31 AM
WannaMini_'s Avatar
WannaMini_
Resurrecting an old thread...
WOW - so easy. I called HMS Motorsport, and got the hardware VERY cheap. 888-467-3269 And they are sending it out today...
gnhovis
Dec 14, 2015 05:31 PM
martinb
Oct 7, 2015 05:00 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
papawhiskey
Sep 30, 2015 02:50 PM
dragonby
Sep 25, 2015 08:10 PM
