Interior/Exterior Stops
Old Sep 21, 2008 | 01:49 PM
CooperWorks's Avatar
CooperWorks
Stops
I would like to know if anyone has ever opened up a stop light, I want to paint it. I don't like the chrome. i'd like to paint it black.
Old Sep 21, 2008 | 02:13 PM
groovetini's Avatar
groovetini
I have. The chrome is easily removed with rubbing alcohol. on 02-04 it's black underneath, after that it's red. I used a combination of heat gun and dremel to remove the top cover.
Old Sep 21, 2008 | 04:09 PM
shooler's Avatar
shooler
I have done it as well, but chose to paint the chrome surround Electric Blue to match the rest of the car. It's not a difficult process (I used a Dremel with a cutoff wheel). Just take your time.
Old Sep 21, 2008 | 04:38 PM
1nf3rn0's Avatar
1nf3rn0
Ya, its easy. Resealing it was a little tough the first time I did it, but a liberal application of silicon does the trick!
Old Sep 21, 2008 | 07:20 PM
xnotfunkylex's Avatar
xnotfunkylex
I did it too. Used a dremel to open them, and then painted the chrome flat black, and tinted the red lens.
Old Sep 21, 2008 | 09:30 PM
//MZero's Avatar
//MZero
Yep...I also did it...search my posts for my pics. I just did a small hole with a dremel where it seals at the bottom of the light, then I gently used a screwdriver to pry around the edges after heating it with a hair dryer...it sounds like its snapping and breaking and making horrible noises, but its ok. I then sealed with liberal amounts of black silicon and its been perfect ever since.
Also since I have Chilli Red, and the 05-06 lights are red underneath I was even more excited when this was done...color matched and dechromed for free!
Old Sep 22, 2008 | 12:52 AM
xnotfunkylex
I used the screwdriver on the first two.
One cracked the lens in half, and the other messed up the black plastic on the lens. I think it's safe to say the dremel all the way around worked much better for me.
Old Sep 22, 2008 | 01:35 AM
Motor On's Avatar
Motor On
I did it a few years back, baked them and they pryed apart just have a good adhesive to seal it back up.
*note this summer (1.5 years later) I have begun to notice wear I tapped to mask off with blue painters tape seems to be attracting quite a bit of dust for some reason.
Old Sep 22, 2008 | 03:15 AM
1nf3rn0's Avatar
1nf3rn0
Heres what mine look like after a year....
Old Sep 22, 2008 | 06:14 AM
CooperWorks
Thanks a lot guys for your help!
Can anyone post pictures of a red mini with the black surround so i can see how it looks.
Old Sep 22, 2008 | 08:41 AM
//MZero's Avatar
//MZero
If you want I may have some time to photoshop yours...it should be pretty easy. Post up a pic and I'll try to have it done by tonight. For now, here is how mine look.
Old Sep 22, 2008 | 09:14 AM
CooperWorks
thanks //MZero
Here is mine.. if you have time please photoshop it
Old Sep 22, 2008 | 09:50 AM
//MZero's Avatar
//MZero
The left one was giving me a little bit of trouble. I could probably re-do it to make it perfect, but I figured this gives you a good idea.
Old Sep 22, 2008 | 11:58 AM
CooperWorks
YEAH !! It's OK. Thanks!!
What do you think ? do you like it black guys? i don't know because of the white roof..
Old Sep 22, 2008 | 01:09 PM
xnotfunkylex
I would do red since your roof is white.
Old Sep 22, 2008 | 01:55 PM
//MZero's Avatar
//MZero
I am also partial to red
Old Sep 22, 2008 | 04:21 PM
K5Cruiser's Avatar
K5Cruiser
I'd say do yours like MZero.
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
M7Speed
Oct 1, 2015 07:05 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
