Interior/Exterior shaved hood
Old Oct 10, 2008 | 04:10 AM
  #26
jerjer's Avatar
jerjer
i think it did already unfortunately but no one can tell from a distance.. haha
Originally Posted by Eurothrasher
Maybe this is a dumb question, but will the area surrounding the scoop that was filled in crack due to exteme temp fluctuations ?
Scoop is ABS plastic, hood is metal and both contract at different temps....just wondered if the "bondo-filler" was going to crack around the edges.
Old Oct 10, 2008 | 08:46 PM
  #27
second to none's Avatar
second to none
Originally Posted by gnatster
One has to use the proper filler material, standard bondo will have issues.
Did you use Rage Gold, or something similar to that?
Old Oct 10, 2008 | 08:48 PM
  #28
second to none
The right body fillers will expand/contract and maintain flexibility with the dissimilar materials, and should not be a problem if performed correctly
Old Oct 10, 2008 | 08:54 PM
  #29
Rally@StanceDesign's Avatar
Rally@StanceDesign
Rage gold is more of a last-step filler.....not as much an adhesive. They probably used an adhesive for the initial bonding and filling and THEN smoothed it off with Rage or something similar
My guess is they used one of the 3m adhesives or perhaps Fusor.
  #30
gnatster's Avatar
gnatster
I don't remember the exact products. We contacted the 3M rep through the body shop and he came out and showed us what we needed. I can say it's held up quite well. There was a little shrinkage after it was finished and fully cured. We were warned of that and told to paint thicker in those areas and come back in 6 months to buff the contraction marks out. Once that was completed it takes a good eye in direct light at the right angle when the car is perfectly clean to notice anything was filled.
One item was big bucks, some type of two part adhesive that came in a big syringe. Other products hardened to a light grey or green or reddish.
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
drum6g
Sep 29, 2015 01:15 PM
