Interior/Exterior Carbon Fiber Hood Specs?
Old Jun 5, 2008 | 11:04 AM
howsoonisnow1985's Avatar
howsoonisnow1985
My GP just got hit on the front side by a driver on a cell phone, it damaged the front fender which is really the bonnet. I want to replace the bonnet for a VIS/Siebon type carbon fiber bonnet. But is it really real CF? How much do they weigh? What does stock bonnet weigh? Anybody done these comparos yet?
One vender quoted me 21lbs for VIS CF bonnet, but need to make sure.
Old Jun 5, 2008 | 11:13 AM
onasled's Avatar
onasled
It's fiberglass matt with a top layer of CF cloth. Weighs a good amount less then steel hood, but a steel hood can get stripped down to the same or close to the same weight. The VIS hood does not fit perfect as far as I know.
I'd consider getting a new steel hood and gut it out as much as possible myself.
Old Jun 5, 2008 | 01:51 PM
UKSUV's Avatar
UKSUV
Go with a ViS instead of the crappy Seibon. And yes, they dont fit well like the OEM hood. Some are better than others tho...
Old Jun 5, 2008 | 08:46 PM
AutoXCooper.com's Avatar
AutoXCooper.com
How would one get that much weight out of a stock hood and still remain street legal?
+1 on the VIS. I have a cheap CF hood and after seeing the VIS at MOTD it's by far the better if not the best of the CF hoods. However none of them fit like OEM steel so if OEM fit and finish are part of your goal get the OEM steel.
Old Jun 7, 2008 | 01:20 PM
howsoonisnow1985
Hmmm, I stripped off the heat shielding, plastic clips, and few foam bits already. And I have the non xenon lights. I guess I'll do the same again.
Any other diet tips especially for front end.
Old Jun 7, 2008 | 04:09 PM
UKSUV's Avatar
UKSUV
You can run a DEKA battery..oh wait...you have an S...nevermind...
Old Jun 8, 2008 | 02:22 PM
howsoonisnow1985
Yeah I'm getting the 11.8lbs Braille from Tire Rack
Boverphoto
Jul 3, 2017 10:56 AM
JCW_Coupe
Oct 25, 2015 06:06 PM
bavmotors
Oct 13, 2015 12:43 PM
Grizld700
Sep 15, 2015 05:34 AM
dube53
R58 :: Coupé Talk (2012+)
Sep 11, 2015 09:30 AM
