Interior/Exterior Help to get the Plug cover tap next to the hand break
Old Aug 14, 2003 | 06:41 PM
ultramini's Avatar
ultramini
Hi,
I was doing so investigation about the 2 plugs tap next to the hand break. I removed on and it accidently dropped into the hole. Now, I can not find it. Do you know how to get it out? Thank you for your helps.
Ultramini.
Old Aug 14, 2003 | 07:46 PM
mightyMiniz's Avatar
mightyMiniz
Ok I did the same thing....
Get a MagLite
A Pen or something similar.. long and thin...
Reverse a piece of tape on the end... and secure the tape with another piece of tape...
Then Probe that sticky stick in there until you pull out the cap.
Good Luck
Old Aug 14, 2003 | 07:54 PM
ultramini's Avatar
ultramini
Thank you for the reply. The problem is that I cannot see the tap. I think I am going to use the vaccum to suck the tap to the place where I can see it. Than use your suggestion to get it out. Thank you.
Ultramini
Old Aug 17, 2003 | 02:31 AM
Kohu'ulaMINI's Avatar
Kohu'ulaMINI
....that sounds too funny.....
Old Aug 17, 2003 | 02:49 AM
mightyMiniz
HEHEHEHEHEHE
Old Aug 17, 2003 | 08:25 PM
ARitz's Avatar
ARitz
You may want to put like a wire mesh or net over the end of the vaccum, and then it would just be sucked up against the the mesh instead of being sucked all the way in.
-Andrew
Old Aug 18, 2003 | 07:39 AM
MINISPIDER's Avatar
MINISPIDER
What the hell r u guys talking about?.....Is this encrypted info?....
Old Aug 18, 2003 | 08:32 PM
MINIACK's Avatar
MINIACK
Does anybody know how to just remove the center console? I was looking at the cap myself and dropped it in. Before I was able to fish it out I was considering taking the console off. I gave up, and was able to get the cap.
I would still like to know how to remove it though.
MINIACK
09R56
Nov 16, 2022 10:49 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
minipopkart
Aug 13, 2015 05:22 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
