Interior/Exterior Yellow Fog lights
Old Sep 13, 2009 | 08:17 AM
  #151
tintman718's Avatar
tintman718
Hmm....why tint the fog lense when you could just run the proper temp range for yellow wavelength (2500-3200)? It'd be more effective and the performance would be improved.
I have to disagree with you. Being that you have never seen my setup in person I can understand why you would think that. Actually, my setup is brighter and has a much nicer color than a 3000K setup. I have compared to many friends who have 3000K kits in their cars and it's pretty much agreed that my fogs blow there's out of the water.
Old Sep 13, 2009 | 02:31 PM
  #152
dwf137's Avatar
dwf137
am i reading this right? you put a 5000k hid setup into your foglights and then tinted the lens yellow?
The point of fog lights isn't to be the brightest. When they're too bright, they don't function as intended.
Yellow is good because it helps visibility in inclimate weather. Producing a 5000k color temp and then putting it through a yellow lens is seriously cutting down on your light output.
Not to mention the fact that if you actually put a 5000k hid kit in your fogs you're blinding everyone on the road.
Old Sep 13, 2009 | 07:24 PM
  #153
tintman718's Avatar
tintman718
When they're too bright, they don't function as intended? Am I reading that right? Brightness is not inversely related to visibility. Brightness along with proper aiming can give you amazing results. Since you've never seen my setup in person I can see why you think that way. BTW, I'm an ASE certified master technician & new york state certified safety and emissions inspector. Making sure lights don't blind anyone on the road is something I know about.
Old Sep 14, 2009 | 01:19 AM
  #154
Sketch's Avatar
Sketch
No need to be rude mate, he was simply goin by what u wrote. And going by what you wrote, I would agree with dmf about blinding people on the road. My 3k nokyas are super bright so I can imagine how 5k looks
Old Sep 14, 2009 | 09:33 AM
  #155
tintman718's Avatar
tintman718
I sincerely apologize if I came off rude, I was just explaining my position.
Old Sep 14, 2009 | 10:32 PM
  #156
Sketch's Avatar
Sketch
no worries man, the interwebz can be confusing lol
Old Sep 15, 2009 | 03:40 PM
  #157
dwf137's Avatar
dwf137
okay, well that's good and all, but if you put hid's into a halogen housing, you're going to have issues with the beam pattern glaring into oncoming drivers eyes, unless you did additional modifications.
also, I've had experience with fog lights that are too bright reducing visibility, yes, reducing. too bright and they start illuminating the fog more then the road. If you don't have much fog in your area, i guess that wont matter.
just throwing it out there.
Old Sep 18, 2009 | 10:34 AM
  #158
BRGminime's Avatar
BRGminime
Nokya H8's installed
I just recieved my yellow fog lamps in the mail. Purchased for $24.99 with free delivery. (thanks to Wolfee for the eBay tip) I got them out of the mail box went straight to the garage turned the wheel and installed them both ASAP. I'll attach pictures later when it gets darker out.
This is my first Mod! I have the super shorty antenna on its way as well.
I guess you could call all the Carbon Fiber parts mods as well but I had that on from the start from the dealership.
Old Sep 18, 2009 | 11:47 AM
  #159
Wolfeee's Avatar
Wolfeee
Yayyyy!!! Can't wait to see them!!!
Old Oct 2, 2009 | 06:44 AM
  #160
BRGminime's Avatar
BRGminime
Here is a picture with the Nokya H8's installed. Not the best picture in the daytime but oh well.
I have also added a picture of the Alta Super Shorty that ALTA says fits on the R57's but if you look at the picture it is far from a good fit other than the right screw thread?!
Attached Thumbnails Yellow Fog lights-nokya-h8s.jpg   Yellow Fog lights-alta-super-shorty-on-2009-mcsc.jpg
Old Oct 2, 2009 | 07:09 AM
  #161
Wolfeee's Avatar
Wolfeee
lookin good!
Old Oct 12, 2009 | 07:12 PM
  #162
Joey D's Avatar
Joey D
Over the weekend while doing my grille swap I installed Hella Yellow Star bulbs into the OEM driving lights. I do a lot of back road driving, which is why I have the driving lights in the first place, and I thought adding the yellow bulbs would help out in in-climate weather. I'm pretty happy with the bulbs so far, although we haven't gotten any bad weather since I've installed them, but with the Michigan winter right around the corner I don't think I'll have to wait all that long.
Based on dry weather testing, the yellow balances out the blue a bit from the HID headlamps and gives more contrast to things on the road. Doing this really makes me want to upgrade my standard fog lights as well to a yellow bulb, although the only ones I found worth their salt are the PIAA Plasma Ion Yellow bulbs and I'm not really prepared to drop $70 on some lights.
If someone has a better suggestion I'd love to hear it, I've had Nokya's in the past as a fog light application and they burned out prematurely. Maybe their quality has gotten better though, I'm not really sure.
Old Mar 20, 2010 | 11:09 AM
  #163
Joey D's Avatar
Joey D
After going through the winter again with HID's and white fog lights I finally decided to order a pair of yellow one so I can see what I'm actually doing in inclimate weather. I got Halo Solaris Yellow H8 bulbs off of Amazon for $20, which isn't too bad. I thought about PIAA's but their life is pretty short and they are $80. If $20 crap out I'll be slightly more ok with it.
Before:
After:
I'm pretty happy with the colour of them, they are not highlighter yellow but rather goldish yellow which is what I wanted.
I'll do night shots when it actually becomes night out.
Old Mar 20, 2010 | 05:58 PM
  #164
Joey D's Avatar
Joey D
So I got some night shots, I'm not really sure how to take these to give off an accurate representation of the light output unfortunately. This gives you an idea of the colour and what not though. And yes my driver side head lamp needs to be adjusted.
Old Mar 26, 2010 | 12:22 PM
  #165
Lil Q's Avatar
Lil Q
I like that pic with the skewed headlamp! Kind of gives it a unique art appeal.
Old Feb 17, 2011 | 06:14 AM
  #166
asciilogic's Avatar
asciilogic
I ordered the PIAA H8 Plasma Ion Yellow to replace my stock fogs. I can't wait til they get here. Will post some before an after pics.
Old Feb 28, 2011 | 08:02 AM
  #167
asciilogic's Avatar
asciilogic
Here are the PIAA Plasma Ion Yellow bulbs. I installed them last week. I've been loving 'em every since.
Old Mar 1, 2011 | 06:49 AM
  #168
LadyGodiva's Avatar
LadyGodiva
Looks great! Good job.
Old Jul 9, 2011 | 01:38 AM
  #169
cesar418's Avatar
cesar418
I just got a set of Nokya H8, and they seem not to be yellow enough, seem more like white yellow, definitely not the lexus fog look that i was going after
Old Jul 9, 2011 | 04:48 AM
  #170
asciilogic's Avatar
asciilogic
Thanks LadyGodiva.
Old Jul 9, 2011 | 04:50 AM
  #171
asciilogic's Avatar
asciilogic
Let's see the pics. I'm sure they look great.
Old Jul 9, 2011 | 09:57 PM
  #172
minimike21's Avatar
minimike21
nokyas are good... but i agree they arent deep yellow... but they are very bright... i am happy with mine...
Old Jul 14, 2011 | 02:32 PM
  #173
cesar418's Avatar
cesar418
pics of my nokya yellow fog, stock wattage
Not as yellow as i wanted (i wanted the lexus look) nor as bright as they were in my e46 bmw, im guessing because of the difference on wattage, but brighter than stock and there is more road path covered by the light
Old Apr 15, 2012 | 05:13 AM
  #174
ThatCooperS's Avatar
ThatCooperS
I just installed my Nokya fog lights and I wanted a deeper yellow so I also threw on a set of lamin-x fog 4" light films. FYI the film is a pain to install on a dome shape. Even using a heat gun, I am still fixing the edges. I might just have to buy another pair of lamin-x and take off the fogs. There is just not enough room to work them on. But I am happy with the yellow it gives. Hopefully get some pics soon.
Old Apr 15, 2012 | 08:03 AM
  #175
asciilogic's Avatar
asciilogic
Some video of the PIAA Ion Yellow Fogs
http://youtu.be/h0YaNHcHsLw
