Interior/Exterior MINI Wings
Old Mar 22, 2008 | 10:42 PM
yellowbritishrocket's Avatar
yellowbritishrocket
MINI Wings
what is the easiest way to remove the MINI wings and install a new set...im getting a custom set at amviv and want to know the easiest way to do it
Old Mar 22, 2008 | 11:38 PM
Bang110's Avatar
Bang110
The one on the front? I am 90% sure it's held on with something sticky. I know there are two little holes under it. What are you getting to put there?
Old Mar 22, 2008 | 11:51 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Something like this????????
http://cgi.ebay.com/ebaymotors/ws/eB...226791449&rd=1
:e ek2:
Old Mar 23, 2008 | 12:44 AM
yellowbritishrocket
a set of carbon fiber vinyl/liquid yellow MINI letter and ring around the letters from langston
Old Mar 23, 2008 | 12:45 AM
yellowbritishrocket
and front and rear emblems
Old Mar 23, 2008 | 04:45 AM
R56 Ed's Avatar
R56 Ed
I think the experts use several pieces of dental floss, and kind of saw back and forth between the emblem and the paint. Totally harmless to both the emblem and the paint. Might have to use 'Goof-Off' to get the remaining double stick tape off the car
Old Mar 23, 2008 | 05:03 AM
yellowbritishrocket
sounds good
Old Mar 23, 2008 | 06:18 AM
edijak's Avatar
edijak
Removal
I agree with the Dental Floss technique. I used it for rear Cooper S emblem to replace with JCW badge after aero and tuning kit. Floss works really well. Expect to break several pieces and take your time. I used 1/3 alcohol and 2/3 H2O to remove the goop left behind.
Old Mar 23, 2008 | 09:58 AM
Bang110's Avatar
Bang110
Same. when I took my "Cooper S" off the back I just used floss. And you will use a good amount. But it was easy. Send us pics of your new badges!
Old Mar 23, 2008 | 11:09 AM
xnotfunkylex's Avatar
xnotfunkylex
Use a little heat with the dental floss. The heat softens the tape a little.
Old Mar 28, 2008 | 12:58 PM
Bang110's Avatar
Bang110
Where are the pics?
This thread is useless with out pics.
Old Mar 30, 2008 | 04:04 AM
MiniGoneWild's Avatar
MiniGoneWild
if its the same as removing the Cooper S badge then heres a step by step made earlier this year by erieman
http://bushfingermini.blogspot.com/2...oval-pics.html
Old Mar 30, 2008 | 12:16 PM
bad venge's Avatar
bad venge
I use fishing line (breaks far less) and 3M adhesive remover
Old Mar 31, 2008 | 04:04 PM
the platform's Avatar
the platform
+1 fishing line
Old Mar 31, 2008 | 07:36 PM
yellowbritishrocket
https://www.northamericanmotoring.co...d.php?t=134481
wings i got from lyle at amviv are on!
Old Aug 11, 2012 | 09:04 PM
oldMGguy's Avatar
oldMGguy
Removed and re-attached both front and rear MINI wing logos for centerline stripe application. The logos are held on with two-sided sticky tape and located with two plastic posts inserted into matching holes in the metalwork. The front logo's pins are different in size from the rear (one pin is bigger than the others). The pins are located centered under the "M" and the last "I".
The Bentley manual recommends using a heat gun or hair dryer to soften the tape. Don't overdo it, as the logos are plastic. Using heat and a tape-covered putty knife, it took less than 5 seconds to lift off each logo with no damage. You can buy a $5 roll of molding tape at any auto parts store and re-use the factory logos.
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
