Interior/Exterior Harness bar
even the other schroth 4 pt. with ASM?
http://www.schrothracing.com/product...allye/rallye-4
that said, end cost is about the same, i'd go with the quickfit anyways
The only difference between the two is that the rally belt has a single center buckle. This is to make it a better fit when used with a Hans device. Not recommended if you don't use the Hans. The belts are a bit to close to your neck and will cause some discomfort.
No need to get a harness bar if you use the MINI specific Schroth 4 point belt.
It is the Quick-Fit that I have and I've come to the understanding now that a harness bar is not required. So I have a bar that is not doing me any good. I hope this discussion helps others to make up their mind about what they should and should not purchase.
So am I correct after reading thru this thread that I don't need to use a harness bar (in my case I've have the Stable Energies type bar) if I'm using the Shroth Quik Fit-Pro 4 point harnesses?? That is what I have for belts...
Cuz I'm about to pull off those B-Pillar covers and mount this bar....
Sorry guy's......didn't see that this thread continued onto page two!
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
atlantaorange
Sep 16, 2015 12:43 PM
