Interior/Exterior side repeaters
Old Feb 20, 2008 | 07:02 PM
  #26
RussellCory's Avatar
RussellCory
There are a lot of different spray paints out there & Krylon is one of the "cheaper" ones. Brands like Belton or Montanna are the best but few people outside of the graffiti art world have heard of them.
The trick to getting Krylon to work relatively well is to shake the can like an aupair shakes a baby. You have to shake the can vigoriously for at least 3 minutes. A lot of times Krylon runs because of a bad mix from the factory. Shaking it really well can help combat it.
Old Feb 20, 2008 | 07:21 PM
  #27
joshamman's Avatar
joshamman
I used Rustoleum Flat black on mine. I really like how they look as flat black:
for comparison, here is what the non-S looked like (had them on for 2 days before I just painted the S ones )
Old Feb 21, 2008 | 04:52 AM
  #28
RussellCory
I dig that super reflective S. Is that a AC one?
Old Feb 21, 2008 | 08:27 AM
  #29
ImagoX's Avatar
ImagoX
I didn't like the quality of the OEM smoked lenses, so I used a can of tail light blackout spray on the repeater lenses - looks better IMHO than the OEM smoked ones, because they're not clear but retain the translucency of the white lens. Two light coats gave a good darkening effect without making the repeater too dark, but I did a third coat for a blacker non-illuminated look.
Just FYI...
Old Feb 21, 2008 | 09:21 AM
  #30
pepegrande008's Avatar
pepegrande008
So im going to do the same as joshamman with the flat black. I want to do the handles, gas cap, repeaters, and other chrome stuff on the car. What kind of prep work do i need to do before i paint the chrome?
Old Feb 21, 2008 | 09:29 AM
  #31
pepegrande008
Also, what kind of prep work and where can i get that blackout paint for the repeater lense?
Old Feb 21, 2008 | 10:43 AM
  #32
ImagoX's Avatar
ImagoX
THIS is what I used... No prep needed, besides cleaning the lens with alcohol to remove all dirt. Just set the lenses in a piece of cardboard, to hold them and catch overspray, and don't put on too thick a coating - the product is quite thin and will run down if put on too thick. Use light coats. if you end up with a slightly "pebbled" coating, a bit of fine-grade polishing product (Scratch-X or Prima Swirl) will restore it to a mirror gloss sheen. Works on tail lights too (although I think using the Lamin-X film there is safer and is removable as well if you change your mind.).
Old Feb 21, 2008 | 11:20 AM
  #33
pepegrande008
So you spray the paint on the outside of the lens right? And do you guys think that adding a primary for plastics for the first coat and then a few layers of clear coat might help with the chipping?
Old Feb 21, 2008 | 11:35 AM
  #34
ImagoX's Avatar
ImagoX
The blackout spray is used on the outside of the lens, yes.
Old Feb 21, 2008 | 12:40 PM
  #35
pepegrande008
*primer
Old Feb 21, 2008 | 12:41 PM
  #36
pepegrande008
I think that its just the reflection from the flash
Old Feb 22, 2008 | 07:43 PM
  #37
yellowbritishrocket's Avatar
yellowbritishrocket
i got a set of AC LY "S" inserts and put them in last night...pics to follow soon
Cereall
Sep 5, 2019 06:05 PM
DeniseNY R52
May 17, 2016 05:16 AM
cm.d
Aug 19, 2015 08:51 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Lt. Dan
Aug 10, 2015 12:46 PM
