Interior/Exterior CF gauges
Old May 3, 2012 | 05:14 PM
  #76
SMOG's Avatar
SMOG
Alliance Member
I too like the look of Carbon Fiber.
I am trying to get the products that these folks sell. As yet they do not have the R-56 gauge faces but they are working on it.
http://essentialmini.co.uk/
At least they speak English and reply in a prompt courteous manner
Old Apr 19, 2017 | 12:42 PM
  #77
rckrzy1's Avatar
rckrzy1
Originally Posted by tominizer
Celia..................... I'd also be REALLY interested in knowing how your husband just removed the clear gauge cover faces to install the new layovers. That would be a HUGE time saver.
On zero-ing out that needle, that sounds like a bit of an issue. The distance that it falls after the fact, try installing the needle that much further ahead (if that makes sense) and maybe it may fall back into alignment. Otherwise, I have no suggestions for you on that one. I know that sometimes vinyl gets cut enough to slip it over the needle withotu having to remove it........... not sure about in this case.
Sorry to open up an old thread but I find it hard to believe this can be done. I've searched alot of forums and threads.
Old Apr 20, 2017 | 07:34 AM
  #78
SMOG's Avatar
SMOG
Alliance Member
I gave up trying to do this and if I want black gauges I will have MINI install the JCW Speedo and tach at a terrible cost!
Old Apr 23, 2017 | 06:42 AM
  #79
rckrzy1's Avatar
rckrzy1
Ok, I stopped after removing speedo bezel with vent cover and was able to use different screw drivers and finger to get to the tabs holding the clear lens and black ring under that. I found no need to go any further. Still a bit of work, especially getting those top torx back in that are accessed thru the top vent. And people say the tach is hard to remove the needle and the speedo was easy. On my 2013 it was opposite, tach came off easier, speedo I was sure something was going to break.
I'm quite pleased with the look. I bought mine on ebay from a guy who thought they were mini mania, but I think they are OM . His pictures and description said black but when I got them they looked dark grey and after installed I'm pretty sure they are grey which is what I wanted anyway.
5EB493E0-3DB7-45EC-96C8-97EAECA094E9_zpsbalrmsbq.jpg~original
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
