Interior/Exterior CF gauges
Old Feb 15, 2008 | 04:04 PM
  #26
benji_mini's Avatar
benji_mini
the emblems are super easy - take a hairdrier (or heat gun) and warm up the emblem then use some floss or fishing line to seperate the emblem from the car itself...once off send to Lyle (or buy the core charge and send him yours after you receive the c ustom ones)
i think custom emblems is the best/cheapest mod you can do - look at these that Lyle made for me
http://www.lylesvinylstyles.net/beta/IMG_3238.JPG
http://www.lylesvinylstyles.net/beta/IMG_3242.JPG
Old Feb 15, 2008 | 04:18 PM
  #27
ghosthound's Avatar
ghosthound
im assuming that border can be done with the CF as well?
Old Feb 15, 2008 | 04:24 PM
  #28
Vinyl Styles's Avatar
Vinyl Styles
Thanx Benji
ghost - Yup, you betcha!
Old Feb 15, 2008 | 09:21 PM
  #29
Vinyl Styles
Originally Posted by MiniJayhawk
Satin black with Chili red borders would be perfect. Or Dark Silver metallic with Chili Red borders. Or . . .
Old Feb 16, 2008 | 06:24 AM
  #30
BlimeyCabrio's Avatar
BlimeyCabrio
Dude, you're getting good at this... I'll be sending you a package in a couple of days...
Old Feb 16, 2008 | 06:30 AM
  #31
Ex-Pat Brit's Avatar
Ex-Pat Brit
Originally Posted by sil3ncer7
I need a center piece that goes under the speedo.. Owner before had to drill into the dash to mount something for some reason. So I might do it if I can find a replacement center piece. Plus Lyle's work OWNES!!!
aethetic creations has a piece for under the speedo, why not try them
Old Feb 16, 2008 | 04:37 PM
  #32
MiniJayhawk's Avatar
MiniJayhawk
Originally Posted by Lagston@VinylStyles
Nice! But after seeing that I think I would opt for a satin black with chili red numerals.
Old Feb 18, 2008 | 02:02 PM
  #33
rattmobbins's Avatar
rattmobbins
Dude, that looks amazing!!!
Old Feb 24, 2008 | 03:15 PM
  #34
<MINI>'s Avatar
<MINI>
Here's some gloss black faces that I'm in the middle of installing right now. I'd be finished, but I can't get the needle off the tach (I couldn't get it off the speedo either, but I was creative and made it work, more on that later)
How the f_*& does the needle come off??? I've seen the threads on removing needles on the 1st gen. MINI's, but the R56 is different. I'm dying here, my fingers are killing me and I'm burning daylight!
Old Feb 24, 2008 | 04:06 PM
  #35
Vinyl Styles
That looks great Robb!
I don't know if these will help at this point, but I've found that this is the best way to remove the needle. Use three fingers to kinda "pry" the needle up and off. It is going to require a lot of force tho.
^ This is what the needle looks like when removed - male/female style ^
Old Feb 24, 2008 | 08:28 PM
  #36
xnotfunkylex's Avatar
xnotfunkylex
I might have to get a set of those carbon gauges for my R50 soon. And your new U/J logos. Your work is just awesome.
Old Feb 25, 2008 | 06:37 AM
  #37
MiniJayhawk
So how freakin' hard is it going to be to get the speedo needle accurate at zero again???
Old Feb 25, 2008 | 02:57 PM
  #38
VicSkimmr's Avatar
VicSkimmr
OMG thats hot. That looks great!
On a side note, is there any way of adjusting how bright the lighting for the numbers are? At night it would obviously not be a problem, but during the day I think it might be difficult to read.
Old Feb 25, 2008 | 04:22 PM
  #39
<MINI>'s Avatar
<MINI>
Visibility during the day is no problem and the dash lights are adjustable, as all cars are.
Old Feb 25, 2008 | 04:44 PM
  #40
<MINI>'s Avatar
<MINI>
Well, I got it finished. I never did get the needles off. I even tried vise grips with no luck. My fingers still hurt today. The speedo was easy to put on without removing the needle by cutting as shown in the pic. I did the same thing for the tach, only making the cut in a straight line from the center of the needle to the "0" tick mark. This way the cut is not visible with the car turned off, it's really not noticeable when running either.
As you can see, I used a black Sharpie pen to fill in around the gas/seatbelt icons, as well as around the lower section. I did this to fill any voids. The new faces lined up perfectly on all the numbers/tick marks! At first I thought the face needed to be opened up a bit, but then realized with some work it slides under the plastic trim.
Now that it's finished, the hardest part were the needles. Everything else was actually pretty easy. The instructions and pictures I found here (post #22): https://www.northamericanmotoring.co...d.php?t=126681 and the gallery here: https://www.northamericanmotoring.co...y.php/cat/1973 guided me through the whole process.
Keep in mind that the Speedo and the CD are ONE UNIT. I removed the key fob section and loosened the glove box side of the color line to allow it to slide out. I pulled it out at an angle and then removed the speedo from the rest of the unit without having to unplug everything.
I have some pictures of it all finished, lit up as well, but I have reached my gallery limit, so I'll have to be creative to get some more pix up.
...I also did the "joey mod" this weekend. EASY!!
Old Feb 25, 2008 | 05:04 PM
  #41
<MINI>'s Avatar
<MINI>
Some more pics...
Sorry the link didn't work.
Old Feb 25, 2008 | 05:12 PM
  #42
benji_mini's Avatar
benji_mini
cant access them - asking for a road runner username/password
  #43
MiniJayhawk
Pics don't work for me.
Old Feb 25, 2008 | 05:56 PM
  #44
<MINI>'s Avatar
<MINI>
Let's try again...
Here's part of the mess-
...and some lit up. ( While the numbers look almost black against the silver face, they're really much lighter against the black during the day)
Old Feb 27, 2008 | 05:52 PM
  #45
Minidrivr's Avatar
Minidrivr
Excellent! Black looks great with the Piano black trim.
Old Mar 1, 2008 | 05:06 PM
  #46
Ignigena's Avatar
Ignigena
I really like the black look of the gauges. I don't suppose there's any hope of getting something like this for those of us with a navigation system built in the speedo (R56)?
Old Mar 1, 2008 | 05:43 PM
  #47
Minidrivr's Avatar
Minidrivr
Do you mean the slim area around the nav screen that shows MPH? Everything else around the Nav is already black.
Old Mar 1, 2008 | 06:23 PM
  #48
Ignigena's Avatar
Ignigena
Yep, that's what I mean. I'll have to wait and see mine in person before I decide for sure ... but I was curious if that was possible or not.
Old Mar 2, 2008 | 08:33 PM
  #49
wetceal's Avatar
wetceal
YEA BABY!
Finally got the chance to put these on! I ordered a set of the custom carbon fiber gauge faces from Lyle. I had him put Laser Blue around the numbers and I think it looks SWEET with the CF dash!
It was also pretty easy to do. Of course it helped that my husband had taken the entire dash apart before. He was actually able to install these without removing the entire housing from the dash. He was able to remove the clear fronts, install the gauge faces and replace the covers.
It REALLY changes the entire look of the interior! Whatcha guys think??
Thanks,
Celia
Old Mar 3, 2008 | 04:00 AM
  #50
BlimeyCabrio
Hot!
