Interior/Exterior CF gauges
Old Mar 3, 2008 | 10:42 AM
  #51
<MINI>'s Avatar
<MINI>
NICE! Very clean, the grain all going the same direction even. Very nice car.
Old May 16, 2008 | 09:44 AM
  #52
msh441's Avatar
msh441
Originally Posted by MiniJayhawk
So how freakin' hard is it going to be to get the speedo needle accurate at zero again???
I'm facing exactly that problem right now, myself.
I'm on the verge of a panic.
I just disassembled my center console and installed a piano black overlay on the speedo. It looks terrific with the black domed decal on my center stack. Basiclly only the tach has a white gauge face now, and everything else in the car is redwood red or piano black.
One not-so-little problem: after reinstalling the speedo needle... the speedo does not want to stay zeroed!!! I'll drive around and push the needle into place to match the digital readout. Stop and start a few times to make sure it stays that way. Then when I go park... a few minutes later the needle drops down below its normal just-slightly-below 0 MPH position... and WAY-down over the LED horizontal screen a bit. Start and drive off, and it's now 5-7MPH slow on the needle vs. the digital. Pull the needle off and reposition. Stop and shut down and it does the same thing a few minutes later.
Anyone know WTF is going on!?!
Please help!
Old May 16, 2008 | 11:39 AM
  #53
white rocket's Avatar
white rocket
Chili Red background and I'm in for sure
Old May 22, 2008 | 09:56 AM
  #54
coobah's Avatar
coobah
That looks AWESOME!!!
Love the CF dash too.
Old Nov 29, 2008 | 05:16 PM
  #55
Jankjo's Avatar
Jankjo
Originally Posted by wetceal
Finally got the chance to put these on! I ordered a set of the custom carbon fiber gauge faces from Lyle. I had him put Laser Blue around the numbers and I think it looks SWEET with the CF dash!
It was also pretty easy to do. Of course it helped that my husband had taken the entire dash apart before. He was actually able to install these without removing the entire housing from the dash. He was able to remove the clear fronts, install the gauge faces and replace the covers.
It REALLY changes the entire look of the interior! Whatcha guys think??
Thanks,
Celia
Celia,
Those gauge overlays are a perfect match for your car!
How did your husband remove the clear fronts without removing the entire housing from the dash?
I'd love to do this mod, but <mini>'s photo is pretty scary looking!
Old Nov 30, 2008 | 11:30 PM
  #56
Hoopty's Avatar
Hoopty
Custom Colors......?
I'm interested in the the attached color scheme for my gauges. These pictures are from the recently released 'electric Mini'. Looks to me like dark- dark gray background with lightish orange numbers. Please let me know if it is do-able and cost and lead time.
thanks, Randall
Attached Thumbnails CF gauges-custom-gauges-1.jpg   CF gauges-custom-gauges-2.jpg
Old Dec 1, 2008 | 12:06 AM
  #57
Vinyl Styles's Avatar
Vinyl Styles
We can do these gauges for ya! I can't tell from the pics, are they metallic or just straight gloss?
To change the gauge lighting to yellow, the LED's would need to be changed.
Old Dec 1, 2008 | 06:11 PM
  #58
Ryephile's Avatar
Ryephile
Originally Posted by Lagston@VinylStyles
HOT!
While you're in there, a spritz of darker something, like a dark gray, would be awesome on the needle hub and MINI-drive surrounds.
Old Jan 1, 2010 | 12:32 PM
  #59
PureWorks's Avatar
PureWorks
Damn it Lyle......every time I think I'm done, you come up with another great product, and here I go again!!! I'll be stopping by soon. Think I want Piano black with chili red for my R53!!
Happy New Year
Steve
Old Jan 3, 2010 | 02:49 PM
  #60
Vinyl Styles
Heheh. Sorry, I think
Happy new year!!!!!!!
Old Jan 4, 2010 | 09:07 AM
  #61
Xeraux's Avatar
Xeraux
I swapped out the gauge lights on my BMW F650GS using LED bulbs from http://www.superbrightleds.com. (Excellent service from them, by the way.)
Does anyone know what LEDs to order to change the gauge lighting from the amber-ish red to blue?
Old Jan 4, 2010 | 10:50 AM
  #62
Vinyl Styles
I'm pretty sure that you need surface mount LED's (High flux).
Not sure if it's 3mm or 5mm.
Old Jan 4, 2010 | 10:54 AM
  #63
Xeraux's Avatar
Xeraux
Yikes!
Thanks for the info!
I'll pass on that one.
On the BMW bike, it was a simple wedge-base bulb swap.
Old Apr 7, 2010 | 04:46 AM
  #64
tominizer's Avatar
tominizer
Celia..................... I'd also be REALLY interested in knowing how your husband just removed the clear gauge cover faces to install the new layovers. That would be a HUGE time saver.
On zero-ing out that needle, that sounds like a bit of an issue. The distance that it falls after the fact, try installing the needle that much further ahead (if that makes sense) and maybe it may fall back into alignment. Otherwise, I have no suggestions for you on that one. I know that sometimes vinyl gets cut enough to slip it over the needle withotu having to remove it........... not sure about in this case.
Old Apr 10, 2010 | 12:26 PM
  #65
dj.papazian's Avatar
dj.papazian
Lyle, it would be awesome if you could do up a set of gray/black gauge overlays as hoopty has posted of the new electrical mini. i think that would make the interior of many minis look very sharp!
Old Apr 10, 2010 | 04:03 PM
  #66
Sketch's Avatar
Sketch
I've been playing with the idea of getting a Ferrari tach overlay made... Except a red version. What do you guys think that would run me?
Old Apr 21, 2010 | 12:16 PM
  #67
dnget's Avatar
dnget
Thanks,
Celia
Celia,
I think I'm like the fourth person to ask you. How did your husband get into the gauges without taking the whole dash apart?
Is there a way to get into the cover from the front?
Old Apr 24, 2010 | 02:40 PM
  #68
minime7748's Avatar
minime7748
I fitted my overlays today and am so pleased with the result. One thing though, the speedo needle seems to jerk slightly when the car is accelerating. Have I damaged the mechanism? Is there any ideas anyone can suggest to fix the problem?
Old Jun 12, 2011 | 01:50 PM
  #69
humph's Avatar
humph
Hi do Vinylstyles do facias for car with Nav installed? My new car is a 2011 UK spec Clubman SD.
Old Mar 14, 2012 | 11:04 AM
  #70
SMOG's Avatar
SMOG
Alliance Member
Thanks,
Celia
Outstanding look! Thanks for sharing this idea.
Old Mar 30, 2012 | 10:47 AM
  #71
SMOG's Avatar
SMOG
Alliance Member
What gauge faces did you use?? They look very good
I managed to get the needle off the tach but I will slit the gauge face plate to install the new ones! Do you have any issues with the needles dragging on the overlay???
Old Apr 2, 2012 | 05:06 AM
  #72
tominizer's Avatar
tominizer
Are these available for Canadian cars??? I'm not interested in the MPH with the KM on the inside, but just KM. If so, sign me up for gloss black with the chilli red numbers please.
Old Apr 2, 2012 | 05:59 AM
  #73
SMOG's Avatar
SMOG
Alliance Member
Check out these.
http://www.heiler-tachodesign.de/Spe...R55-MPH-to-KMH
You can get them in a variety of styles/colors/readouts.
Old Apr 11, 2012 | 07:17 AM
  #74
SMOG's Avatar
SMOG
Alliance Member
UPDATE of this project:
I tried many different times to order the instrument faces from this company ( Tachoscheibe Tachofolie Tacho Folie Scheibe Meilen Km/h Mini R55 Umskaliert von MPH zu KMH ) and even though they advertise that they take PayPal it appears that in reality they do not. Their ability to communicate in English is virtually non-existent. When the copies of of the PayPal emails to me were presented to them they claimed they were fake. I spent a considerable amount of time on the Phone with PayPal and they say that these people are not a "Registered" site.
Steer well clear of these scammers!
I am now searching for another provider of instrument faces...
Old May 3, 2012 | 04:57 PM
  #75
inkspot1967's Avatar
inkspot1967
i like the carbon fiber
