Interior/Exterior My New Seats
Old Jan 11, 2008 | 12:12 AM
xnotfunkylex's Avatar
xnotfunkylex
My New Seats
So I finally got around to taking pictures of my new Recaros that I installed a while ago. They are Recaro SRD's and I bought them from http://www.speedwaremotorsports.com/. Their shop also made the brackets to fit my car. All I had to tell them was the build date and the brackets fit with no modifications. I only had to buy shorter bolts to both it to the chassis. These seats are super comfy for my daily driver, but I wish I would have got the adjustable height mounts because they sat too low for me. For that fix I used about an inch worth of washers and now it sits perfect. Does any one have a better/safer fix than that though? Hope you all like them as much as I do.
Old Jan 11, 2008 | 12:13 AM
xnotfunkylex
Here's a few more
Old Jan 11, 2008 | 12:16 AM
Shrashmere's Avatar
Shrashmere
awesome! i like the matching stitching and stuff!
Old Jan 11, 2008 | 01:53 AM
WC50 408's Avatar
WC50 408
They look awesome only thing I can think of instead of washers check Home Depot for solid aluminum spacers, same thing as washers just one solid piece.
Old Jan 11, 2008 | 05:00 AM
JohnnyG's Avatar
JohnnyG
Hey now, those look great!! I've got a set of Recaro A8's in black leather I'm going to install....may I ask how tall you are? I'll probably get the "height adjust" for mine....also through Speedware....how much was your set up? How did you handle the "air bag" issue?
Thanks for any info you can pass along...I want my install to be as "painless" as possible
Old Jan 11, 2008 | 05:16 AM
the platform's Avatar
the platform
very,very nice!
Old Jan 11, 2008 | 07:27 AM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Looks good....
Jack
Old Jan 11, 2008 | 07:42 AM
grillhands's Avatar
grillhands
Any problems with the airbags or anything like that?
Old Jan 11, 2008 | 07:43 AM
AstroBlackS's Avatar
AstroBlackS
Look sweet!
Old Jan 11, 2008 | 07:53 AM
UKCoopeR's Avatar
UKCoopeR
if you wire in the correct resistor no airbag lights, think it is 4ohm, but might want to double check that
Old Jan 11, 2008 | 08:30 AM
///ACS330Ci's Avatar
///ACS330Ci
Very nice
Old Jan 11, 2008 | 01:31 PM
xnotfunkylex
I am about 6' 1" and with the speedware brackets my head was around the height of the door. It just felt very uncomfortable for me. And lets just say that my set up is probably quite a bit cheaper than yours. The A8 are awesome seats.
As for the airbags, I wasn't sure how to install the resistors or what type so I have the warning light on. But since the warning light doesn't effect the functionality of the other bags, I have yet to install a resistor and have the light turned off. Think of it as mood lighting.
Old Jan 11, 2008 | 01:47 PM
Chase's Avatar
Chase
very nice man.
Old Jan 11, 2008 | 08:55 PM
Duck360198's Avatar
Duck360198
Looks real nice...
Old Jan 12, 2008 | 04:24 AM
muggy's Avatar
muggy
perfect match...doesn't get much better than that
Old Jan 12, 2008 | 04:55 AM
PGT's Avatar
PGT
the dealer can reprogram the airbag system for you...they'll charge you an hour of labor.
for the resistors, cut the yellow plug off and put a resistor across the leads. best to solder it on, then tape it up. be sure to keep the plug in case you ever go back to stock. I needed 2.5ohm for mine....be sure to use 1/2 watt or larger.
Old Jan 12, 2008 | 06:28 AM
kenchan's Avatar
kenchan
dayamn!!
Old Jan 12, 2008 | 07:10 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
I really like those seats in your Mini. They look nice and have plenty of support.
Old Jan 12, 2008 | 09:22 AM
cristo's Avatar
cristo
Alliance Member
They look nice!
Old Jan 12, 2008 | 05:21 PM
xnotfunkylex
Thanks for all the nice comments. And PGT, I think I'd rather have the light on then go to the dealer for that price. Maybe my local shop can do it for me. And should it be 2.5 ohm for mine as well or does it differ?
Old Jan 12, 2008 | 06:35 PM
PGT's Avatar
PGT
you have to measure. agreed on the price - ripoff, and mine's back on even after a second trip. they pretend they're doing me a favor not charging me a second time, yet, I feel the $$ spent was a ripoff since it didn't even stick
Old Jan 12, 2008 | 09:02 PM
xnotfunkylex
Thanks for the info. The light doesn't really bother me so I might not even bother to fix it. But I am taking them out soon to fix a few things, so maybe I'll just do it then.
Old Jan 12, 2008 | 09:30 PM
PGT's Avatar
PGT
I'm considering pulling my dash out again and disabling the light if the dealer pulls that BS again
Old Jan 12, 2008 | 09:47 PM
tazio's Avatar
tazio
I used a 3ohm resistor for my driver's side airbag. No issues.
Old Jan 12, 2008 | 10:05 PM
COR BLMY's Avatar
COR BLMY
Couldn't I wire the resistor to 2 pig tails ?
Is a resistor "directional" or just the color code spripes painted on it.
I hope NOT to look like a idiot at Radio Shack.
