Interior/Exterior Removing the Front Doors Windows
Old Nov 25, 2007 | 01:10 PM
raz636's Avatar
raz636
Does anyone know how to remove the front door windows? I've already removed all the screws and see that the whole assembly is loose but it doesnt look like it's gonna come out. Anyone done this before? Im trying to remove the panel/window assembly.
Old Nov 25, 2007 | 05:33 PM
Nicholi's Avatar
Nicholi
The entire door comes out in one piece. However, you do have to remove the glass like you're thinking.
There are a couple bolts that run through holes at the bottom of the glass. If you take these out, the window will come off easily. The trick is that the bolts have a "dead space" with no threads, so you can't just unscrew them. Once unscrewed most of the way, you have to pull the head out with a small pry tool and keep unscewing in order to catch the second set of threads.
Also, if you haven't gone too far, mark the alignment of the window in reference to the door seal, this will help when re-aligning later.
Old Nov 26, 2007 | 08:10 AM
Nicholi's Avatar
Nicholi
raz636 (via pm): "I see only one bolt that I can access that looks like its holding the window. It's the one that can be seen through the 5.25" speaker. Is there another one on the other side?"
Its been a while since I removed the window, but I'm pretty sure there are two bolts, one on each side. I had to tighten one and use it as a pivot point in order to properly re-align the window.
Old Nov 27, 2007 | 07:55 PM
going4speed's Avatar
going4speed
why remove the windows
What are you doing in the door that you need to remove the glass?
Old Nov 27, 2007 | 08:57 PM
raz636's Avatar
raz636
Gonna put in Dynamat Extreme on the outer skin and probably add some Dynaliner or some other type of sound absorbing foam on top of that.
I still can’t figure out how to get to the bolt on the other end of the glass. Has anyone else successfully removed the glass/door assembly?
Old Nov 27, 2007 | 09:21 PM
Msteadman's Avatar
Msteadman
Just so you're aware, other NAM'ers have tried to add dynamat to the front doors without any success. Apparently there's a lack of space for it to be applied. Might wanna conduct a search before going through all that work to just be disappointed.
Best of luck!
Old Nov 28, 2007 | 10:20 AM
pdoyle's Avatar
pdoyle
Msteadman, are you sure about that (lack of space)? IIRC (and I may not) I thought that the lack of space is for those trying to install some Dynamat w/o removing the entire window cartridge. There is very little access to the outer shell. And, as Raz636 is finding out, removing the window cartridge is not easily done.
Pat
Old Jan 3, 2008 | 09:45 PM
raz636's Avatar
raz636
removing the glass
I just found out how to take the glass out. I got this info from another post (https://www.northamericanmotoring.co...68&postcount=6).
"2. Locate and remove 2 silver dollar size rubber plugs that give you access to the brackets that hold the glass.
3. Position the window so bracket bolts are visible in the plug holes then loosen the bolts."
Now I should be able to dynamat those front doors .
Old Jan 3, 2008 | 10:26 PM
Robin Casady's Avatar
Robin Casady
One person here reported that she had Dynamat professionally installed in the doors. So, there is probably room for it. However, she had problems with a door latch after the install. The installers told her to take it to the dealer and they would pay for it. It seems that getting it all out and putting it all back is rather difficult. The installer also said they would charge a great deal more if they ever did it again.
Old Feb 10, 2008 | 09:11 PM
raz636's Avatar
raz636
Pics of Inside the Door
So I finally got around to taking apart the doors. Here are some pics of inside the door and of what I did.
As you can see, there isn't much flat space to cover with sound deadening mat. The foam stuff I used is Overkill and that other little square in the bottom left is a DynaXorb.
Attached Thumbnails Removing the Front Doors Windows-insidedoor.jpg   Removing the Front Doors Windows-dynadoor.jpg   Removing the Front Doors Windows-foamdoor.jpg
Old Feb 11, 2008 | 04:11 AM
lacning74's Avatar
lacning74
Nice job. Persistence and a little OCD pays off. Now you got me thinking about doing this. I will resist.
Dec 23, 2015 10:36 AM
FLYM1N1
Aug 15, 2015 11:20 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
Dashdog
Aug 10, 2015 06:17 AM
