Interior/Exterior R56 Gauge Install - Need Help
Old Mar 12, 2008 | 07:24 PM
  #51
MiniJayhawk's Avatar
MiniJayhawk
Take care of yourself!!!
In the meantime I have decided I am going with a boost/vac gauge and a water temp gauge. Going with the Stewart Warner competition style which is the same manufacturer as the OEM gauges on the previous model JCW. The boost/vac for future mods and the water temp as the earliest warning sign of trouble on the track.
Old Mar 13, 2008 | 06:08 PM
  #52
mikeyb17's Avatar
mikeyb17
Sounds good... I just like the AutoMeter Ultra-Lite II - Never did get a pic up here. Will try to get this weekend.
Old Mar 13, 2008 | 07:11 PM
  #53
MiniJayhawk
I was going with the Ultra-Lite II until I discovered the Stewart Warner gauges were the OEM gauges on the prior model and are silver faced, backlit and look a little more stock than the Ultra-Lite II. I think both are great solutions that will look stock in place.
Old Mar 13, 2008 | 11:51 PM
  #54
mikeyb17's Avatar
mikeyb17
I guess that since I've always had gauges in my cars that were aftermarket and some cars just could never be matched I'm more used to having a gauge that doesn't match.
I remember the days long before we had LEDs and the lighting in gauges was terrible to say the least. The lighting these days is phenomanal .
Old Mar 21, 2008 | 06:51 PM
  #55
aiki10's Avatar
aiki10
Hey there! Getting Ready to Tackle a Gauge Install...
Good evening! Did this project ever run to completion?
Wanted to see if anyone is interested in continuing this... I'm probably going to have a local machine shop modify a manifold... I've got the remainder of the Bill of Materials to solve this and if folks are still interested I can put some notes together when I'm finished and post them...
Would anyone be interested in purchasing a modified manifold/adaptor kit? It's probably going to be pretty costly, in the end... (and if anyone has an adaptor source, I'd like to know about it! Maybe that's why there aren't any recent posts... :-) )
Best!
-jw
Old Mar 21, 2008 | 08:25 PM
  #56
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
You have seen these right?
http://www.jscspeed.com/mini_r56/int...p_vacblock.htm
I bought the top one, works great.
Old Mar 21, 2008 | 09:28 PM
  #57
aiki10's Avatar
aiki10
Thanks!
Hey there! Thanks! The original project was about finding a way to install an oil pressure/temperature sensor, though... :-) I'm looking for something similar to provide access to multiple ports coming off of a handy place to sample oil under pressure... Also need to provide access for the OEM pressure sensor/switch to keep the ECU in line...
Old Aug 22, 2008 | 03:26 PM
  #58
bushman66's Avatar
bushman66
Bump. Anything new on this from aiki10 or Mikeyb17?
Old Aug 22, 2008 | 03:39 PM
  #59
aiki10's Avatar
aiki10
Yep...
The design is pretty much done... I've got a machine shop down the street that I'm talking to about slightly modifying a stock hydraulic manifold. The cost is a little on the high side, frankly, but I think I'm probably going to go through with the installation in early October. I may put a kit together if folks are interested... I was kind of hoping that, in the interim, someone would offer a similar kit, but I've not seen anything yet...
Old Aug 22, 2008 | 05:18 PM
  #60
bushman66's Avatar
bushman66
Great! I'd definitely be interested (and I bet a bunch other will as well) so let us know how the install goes!
Old Feb 24, 2009 | 07:58 AM
  #61
Lil Blue Coop/Mini Rose's Avatar
Any new info?? Also, were did you all get power from for the gauges? is there a free fuse outlet on the fuse block that i can use? thanks,
Old Mar 17, 2009 | 04:41 PM
  #62
Tron Chief's Avatar
Tron Chief
Gauges
I used Marshall Gauges out of Anaheim they match the interior perfectly. Amber backlighting and silver faces. Ended up using Alta for the boost pick off and M7 for the water temp along with a Craven Speed A frame and pods. Extremely happy with the results. Several pictures in my gallery.
John
Old Mar 17, 2009 | 04:47 PM
  #63
Tron Chief's Avatar
Tron Chief
Power for the gauges mine are powered from the relay block drivers side of the engine by the firewall the advantage is they stay on for a minute after engine shut down should any issues arise. However alternate power and lighting is available by going to Alta website they have instructions with their gauges. I did use the DSC for light control and power would have been easier to hook up down there had I seen these instructions prior to installing mine.
John
Old Mar 17, 2009 | 06:03 PM
  #64
IzzyG's Avatar
IzzyG
How would you install the water temp sensor without using M7's adapter?
Old Mar 17, 2009 | 06:15 PM
  #65
Tron Chief's Avatar
Tron Chief
I have seen several posts where they drill a hole into the overflow bottle not a real accurate reading and the M7 adapter just drops into the hose in place of a plastic coupling see the link below.
http://www.m7tuning.com/parts/produc...roducts_id=128
Old Mar 17, 2009 | 10:16 PM
  #66
dwf137's Avatar
dwf137
^did you need to drain coolant for the install of the m7 adapter?
Old Mar 18, 2009 | 04:26 AM
  #67
Tron Chief's Avatar
Tron Chief
Drain no however we lost about 1 pint which we were able to replace once done.
Old Jun 7, 2009 | 11:11 AM
  #68
john171's Avatar
john171
Has anyone found a solution to the Oil Pressure/Temp gauge tap-off for the R56, and/or has anyone heard from the OP mickeyb17?
I have contacted the folks at Grassroots Garage to have my name added to their list, they are working with Craven Speed on a solution, and I was wondering if anyone has heard anything.
Last thing I remember was him posting about his health issues.
YO, mickey you out there?
Old Jun 16, 2009 | 02:13 PM
  #69
johne123's Avatar
johne123
Looks like Craven's should be done soon:
http://www.cravenspeed.com/index.php?productID=220
I have a prototype made that's similar to theirs but still needs a final modification. However I can't completely mine until there's income, if you know what I mean.
Old Jun 17, 2009 | 03:40 PM
  #70
Dwight Walhood's Avatar
Dwight Walhood
Craven Oil Pressure Adaptor
Craven expects to have their oil press/temp adaptor ready the first week of July. It's intended for only one sender, but, it does have 3 mounting ports! It might be possible to mount both pressure and temp senders if you can find room for them and wiring. I'm on their list!
PS: Just got their bracket & pods today and did a quick lookee-loo install using AutoMeter Phantom 52mm gauges. Looks better than OEM. They do a very high class piece of work, IMHO. Dwight
Old Jun 17, 2009 | 04:40 PM
  #71
john171's Avatar
john171
Craven Pods
I've been in the process of installing/wiring two Prosport Gauges (Water Temp & OiL Press) using the Craven dual pod to be mounted on the left of the tach using their "A" adaptor, the arm & ball for the Garmin already occupies the right side. They certainly do make quality products, and I'm on their list for the oil sending adaptor
Old Jun 17, 2009 | 04:46 PM
  #72
john171's Avatar
john171
Wiring Taps
John
John, when you installed your gauges what color wire did you tap into for the lighting? I'm reading to use the gray wire from the bundle that goes to the instrument cluster, ie the tach etc, but the only gray wire in that bundle also has a yellow stripe.
Any help will be appreciated.
John
Old Jun 17, 2009 | 05:39 PM
  #73
Tron Chief's Avatar
Tron Chief
John
Route your wire down to your DSC button and pick the light wire up there. Also I hear that Marshalls Gauges is modifying their font to match the Mini Cooper. I have enjoyed the look and use of the boost/vac and water temp gauges. Orange thru the gauge with silver face and black ring matches my piano black interior.
John
squawSkiBum
Oct 2, 2015 09:21 AM
Minii cooper bean
Aug 11, 2015 02:10 PM
dchang0
Aug 10, 2015 03:37 PM
