Interior/Exterior question about the toggle switch panel
Old Oct 14, 2007 | 06:03 PM
pimpedout97x's Avatar
pimpedout97x
the board behind it, for my extra toggle i bought, im gonna use it as a remote **** for my amp, for my sub. its going to spin, not toggle up and down like the windows, lock, fog, etc.
so, the board behind it is in my way. this is what i need cut out. if i cut thru what i have marked in red(the square) will i mess any of the other 5 switches up?
Old Oct 14, 2007 | 07:05 PM
TWISTER's Avatar
TWISTER
Ask GBMINI aka Ian Cull
Old Oct 14, 2007 | 07:21 PM
GBMINI's Avatar
GBMINI
Another picture here (upside down from yours)
Of course be careful not to cut in to that track running just left of where you highlighted. It's one of the dash lighting tracks.
What I can't remember is what's on the other side of the PCB. I think there's nothing there, in which case "no problem"
Old Oct 14, 2007 | 07:28 PM
pimpedout97x
that's the problem. on the back there is lines:
Old Oct 15, 2007 | 05:40 AM
GBMINI's Avatar
GBMINI
On that newest picture you have ...
highest track drives the front fog lamp
next (going to hole by the arrows) is rear fog so you don't care about that one
next is front fog switch
the lowest two are passenger window up & down
If you have to cut through some, you could then solder a thin wire link - each track has a hole at each end so you have somewhere to solder in to. But put VERY LITTLE solder on the front of the PCB if you do this, or you might affect the switch contacts.
Old Oct 15, 2007 | 07:02 AM
pimpedout97x
crap, this isnt going to work....
Old Nov 14, 2007 | 12:02 AM
xkot's Avatar
xkot
another question about the rear fogs... if i do install a switch into the old bank, can the dealer turn on the function?
Old Nov 14, 2007 | 12:25 AM
Eric_Rowland's Avatar
Eric_Rowland
CAN they? Probably. WILL they? I'm guessing no unless you know the guys. The dealership I bought my 'previously owned' MINI from whined for quite a while about reprogramming the BC1 even though I had the new toggle rack (though it was not yet installed.)
surfblue
Oct 24, 2018 01:20 AM
nshannon29
Aug 25, 2015 11:41 PM
gknorr
Aug 24, 2015 06:39 PM
Chippawaguy
Off-Topic :: Autos
Aug 19, 2015 11:30 AM
