Interior/Exterior Mystery of the disappearing windshield washer solution solved.
Old Aug 28, 2007 | 06:49 PM
rwkeating's Avatar
rwkeating
Although I rarely use my windshield washers, I've had to fill up the reservoir more times than is reasonable. I couldn't figure our where the fluid was going, until the other day. Turns out that the cover ofthe reservoir is coming loose, and then under very hard braking, the windshield fluid is spilling out. Kind of funny now that I've discovered the mystery.
Anyway, now I need to figure out how to better secure the top of the reservoir. I could zip tie it, but I'd like something I could do and undo.
Anyone else experience this problem? If so, how did you solve it?
Old Aug 28, 2007 | 08:07 PM
minjae's Avatar
minjae
is that wat happens?
i knew my fluid runs out really quick but i figured it was cause when shooting at the windshield it shoots 4 little sprays that are jet like which therefore wastes the fluid by spraying it all over the car.
i too would like to see a solution. (if there is one..)
Old Aug 28, 2007 | 08:38 PM
El_Griton's Avatar
El_Griton
Mines always out cause its also hooked up to my IC sprayer
Old Aug 29, 2007 | 12:40 AM
SayGoodbye's Avatar
SayGoodbye
Old Aug 29, 2007 | 01:38 AM
ScottRiqui's Avatar
ScottRiqui
Well, I can tell you that while you're prepping your MINI for an autocross day, it's *not* a good idea to top off the washer reservoirs "since I'm under the hood anyway".
After my first run, there was so much fluid dripping out from underneath the bonnet that I thought I'd sprung a leak in my radiator.
Old Aug 29, 2007 | 02:03 AM
everytimeidie027's Avatar
everytimeidie027
I'm trying to use up the fluid in the tank so I can put water in there so I can use my IC sprayer hahaha
Old Aug 29, 2007 | 05:05 AM
Speedwing's Avatar
Speedwing
VELCRO strap!
Old Aug 29, 2007 | 05:20 AM
kramseib's Avatar
kramseib
I too find my reseviors low and when I check the lids, they are on tight. When I brought my car to the dealer for scheduled maintenance they charged me $6.00 to refill them!!! YIKES!!! Now that's a perfect example of a RIP-OFF!!! Especially when I can buy a gallon of this stuff at the auto parts store for a mere $1.00!
Old Aug 29, 2007 | 06:52 AM
Kentiki's Avatar
Kentiki
Does anyone know how to access the reservoirs? I suppose it involves removing the side panel of the body.
Ken
Old Aug 29, 2007 | 06:54 AM
Loony2N's Avatar
Loony2N
Unless you are track racing, if you are losing that much washer fluid from braking, why are you braking so hard???
Old Aug 29, 2007 | 07:15 AM
minimusprime's Avatar
minimusprime
Originally Posted by Speedwing
VELCRO strap!
second. Radio shack has them so does BB.
Old Aug 29, 2007 | 06:39 PM
rwkeating's Avatar
rwkeating
Ding ding ding, we have a winner . HPDE is where I found out what was going on with the disappearing fluid. I've used more washer fluid by doing HPDE and autocross than I have by cleaning my windows ?
Old Jul 31, 2008 | 08:37 PM
Superfun's Avatar
Superfun
under warrenty
I had a warrenty issue with the wiper tank/system. took two trips to dealer. first trip they removed tire and fender to reconnect tube to tank..when it happened the 2nd time they zip tied the tube to tank, and when that fell off they did it again...amazing. only 9000 miles on car
Old Jul 31, 2008 | 10:16 PM
chaseabryant's Avatar
chaseabryant
Ken
You have to open your hood, remove your wheel, remove your wheel well liner, and viola! There it is tucked up under the side panel. The side panel is not easily removed, I tried to do so a little while ago, however, several of the bolts holding it on are literally painted on. If you had a torx set that can go on a ratchet, then you might be able to remove the side panel.
-Chase
Old Jul 31, 2008 | 10:25 PM
Ancient Mariner's Avatar
Ancient Mariner
Same problem with mine, but when I pulled the fender liner I found that the pump was not fully seated in the tank (rubber ring around it to seal it) and the fluid was leaking from there. A little noodging of the pump assembly, and it popped into place. Nary a leak since.
Old Aug 1, 2008 | 07:18 AM
nixjosh2's Avatar
nixjosh2
VELCRO strap!
I have used these for a while now, and it still leaks out under hard braking, just don't fill em up as much is the best thing, or if there was some kind of gasket made for the lid that actually sealed correctly
bahman
Feb 14, 2016 10:29 AM
rikaro
Nov 24, 2015 02:05 PM
eMINI of the State
Oct 2, 2015 03:12 PM
Suspension Products
Oct 1, 2015 11:53 AM
