Interior/Exterior Gas Cap Relocation
Old Aug 24, 2007 | 10:17 AM
familiarstranger's Avatar
familiarstranger
Gas Cap Relocation
Alright I am going to be having my drivers side rear panel replaced due to a little collision and thought I would look into this while it would be in the shop. so... I know i would be moving the filler line (or replacing if not long enough) welding a cover for the previous locationg and shaving it smooth. a mounting solution for the tail with a hinge. some electrical wiring movement. What else am I looking to have done. how many hours of labor etc.
I looked on the vortex and couldnt find anything but pics, I'll keep looking but thought someone else might know better. Thanks guys!
Bryan
Old Aug 24, 2007 | 10:18 AM
Loony2N's Avatar
Loony2N
I have no idea, but where are you planning to move it and why?
Old Aug 24, 2007 | 10:22 AM
familiarstranger
I want to move it behind my drivers side tailight. I am looking at making the car as "clean" as possible.
Old Aug 24, 2007 | 01:14 PM
a96bimmerm3's Avatar
a96bimmerm3
Theres an amp behind the taillight pretty much. I've taken off some of the panels and you should probably leave things put, imo!
Old Aug 24, 2007 | 01:25 PM
glnr13's Avatar
glnr13
the left tail has nothing behind it... which is actually where one would want to move it since the oem setup is on the left side.
a rerouting to there would be awesome by the way. ive had day dreams of moving it to there. it'd have to flip down for clearance of the taillight assembly... hmmm. good luck and stick to your guns, don't let the naysayers change your mind
Old Aug 24, 2007 | 01:36 PM
Deviant's Avatar
Deviant
It would seem the filler would have to route over the wheel well and then down slightly to the tailight which may be a problem (pumping fuel uphill when refilling) or do you have another idea of how to route the filler?
Old Aug 24, 2007 | 01:38 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I wonder if you could hinge the tail lamp on the bottom to actually be the door, like on the '57 Chevy.
Old Aug 24, 2007 | 01:40 PM
glnr13's Avatar
glnr13
that's exactly how i was thinking... i also saw it on one of rallymini's VW finds. i'll try and find it...
Old Aug 24, 2007 | 02:09 PM
familiarstranger
alright. Glad to see I got some support. I am going to keep looking into this. I have seen it done on a MINI before. the Hinge was on the side. I havent decided how I want to hinge it.
Old Aug 24, 2007 | 02:15 PM
Bradley99's Avatar
Bradley99
Could you recess it into the driver's side door jamb? It would still be outside the door gasket - could make for interesting refuling tho.
Old Aug 24, 2007 | 02:19 PM
familiarstranger
a picture of it on a civic:
glnr13's Avatar
glnr13
here's the one i was talking about... for our MINI's it would have to be on the other side.
Old Aug 24, 2007 | 02:27 PM
familiarstranger
I have seen that picture too. Looks soo good imo
Old Aug 24, 2007 | 03:11 PM
familiarstranger
http://www.motoringunderground.com/f...postcount=3386
Old Aug 24, 2007 | 04:47 PM
Partsman's Avatar
Partsman
Legion_of_Doom
That is some trick sh*t right there! Definitely cool. Man, if I didn't have so many other projects going on, i'd check into that.
Old Aug 24, 2007 | 04:50 PM
Partsman's Avatar
Partsman
Legion_of_Doom
That is about as clean and smooth as you can get. Nice. This thing has to sittin' on air bags.
Old Aug 24, 2007 | 05:12 PM
familiarstranger
yea bags are the only way he could get that low and still be worth having a motor
ryGuyMCS
Oct 6, 2015 12:04 PM
riff42
Sep 22, 2015 03:07 PM
12R58JCW
R58 :: Coupé Talk (2012+)
Sep 17, 2015 12:21 PM
Grizld700
Sep 15, 2015 05:34 AM
