Interior/Exterior How To: Beltline Chrome Blackout
In my effort to continue to contribute to the community. Here is my tutorial on how to install a beltline blackout kit.
http://www.russellcory.com/blog/?page_id=19#Project2
Feel free to give me any feedback, I am trying to improve these tutorials as I go along.
Thanks!
Thanks!
I reccomend counter clockwise, so you can stick it to the man!
ooops
I wish I would've read this months ago. I left the layer of clear film on and now in the L.A. summer sun it is cracking all over. I can peel up tiny spots, but it is not easy. Any ideas on how to remove the film now after it's been in place for sooo long?
Or, you could just sit there very patiently until you pick it all off. I used my X-acto blade to get the peel started. Perhaps if you can get one of the ends started it would come off in a complete strip.
Let us all know what you end up doing, I'll bet someone else has the same problem…
I spoke with a friend of mine who does vinyl. He suggested that you gently heat the covering plastic with a hairdryer or heat gun. Don't overheat! It should make the plastic covering a little more pliable and likely to come off in larger chunks. At least thats what he said…
RussellCory, you may also want to mention to not stretch the tape so than it doesn't put stretch marks in it. MINInurse has blacked out 5 MINIs now, I believe, and has gotten pretty good at it.
Nice job on the DIYs
Thanks! I'll add that to the tutorial.
Ok, the tutorial has been updated. Thanks for the feedback! I knew that there would be steps I'd do but forget to write down…
source for tape
auto body depot has this for about $30
3M SCOTCHCAL Custom Striping Tape + For profesional use in matching existing stripes or creating original stripe designs. + Fabricated from durable, colorfast 3M Scotchcal Film designed to resist chemicals and gasoline. + See 3M Scotchcal Striping Tape Color Availability Grid for color selection. Please note that not all colors are available in every size. COLOR: LOW GLOSS BLACK 1/2 in. x 150 ft., Single Stripe
funny... i just blacked out my mini this weekend... took about 1 hour because i have absolutely no coordination.
i used the 3M scotchcal pinstriping tape, i got it on ebay for $23... 150 ft is a lot of tape, but i did several panels twice because i had bubbles...
and i was super confused at first too because of that darn clear tape over it... i thought i got bad pinstriping tape so i unraveled a bunch and threw it out.
either way, cheap mod and it instantly makes the mini look better!
also, you did a great write up too! thanks for posting it here...
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
Oct 7, 2015 02:12 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
Good write up's
