Interior/Exterior Hood Air Extractor Scoop
Old Aug 28, 2007 | 02:51 PM
  #51
mozzarella's Avatar
mozzarella
Originally Posted by gnatster
Tosses spanner into the works.....
So will this scoop also work with the rumored upcoming DFIC V2?
Will the thing work period? I'm not thinking this will do much for resale. I'm guessing that this only works with M7 IC, makes me wonder what happened with the engineering in the first place that the answer is cut a large hole in the hood.
Old Aug 30, 2007 | 08:37 AM
  #52
trackertracker's Avatar
trackertracker
Peter says ( as of 08/29), two weeks (or so )
Old Aug 31, 2007 | 12:18 PM
  #53
maxmini's Avatar
maxmini
The hold up at the moment is ME. I have had a hectic two weeks and Peter has had the final sign off piece in his hand for at least a week waiting on me to get it installed on my car. I have a easy week coming up and the only guy I trust with a sharp instrument near my car will be back from vacation on tuesday. I will do my best to get it put in and photos taken next week. I will take some shots of the uderside for those that were curious this weekend . Sorry about the delay its my fault this time.
Randy
M7 Tuning
Old Aug 31, 2007 | 12:44 PM
  #54
mozzarella's Avatar
mozzarella
What is this supposed to do and is there any data?
Old Aug 31, 2007 | 12:48 PM
  #55
goaljnky's Avatar
goaljnky
I think it's supposed to help the DFIC reach the efficiency of a stock intercooler.
Old Aug 31, 2007 | 12:52 PM
  #56
mozzarella's Avatar
mozzarella
And to do that all it takes is a skill saw to your hood? What do you suppose a new hood costs. This is by far the most insane "mod" I've seen yet and there are lots to go around.
Old Aug 31, 2007 | 03:04 PM
  #57
trackertracker
Thanks for the update Randy
Mozzarella: once one has done all of the other 'insane' mods this one just seems, well 'normal' .
I have an installer/ painter all set up to go. Astro Black body color for the door handles,gas cap,badges,side grills,interior chrome headlights/tail lights
and custom stuff for the extractor scoop
Old Sep 1, 2007 | 06:53 AM
  #58
MSFITOY's Avatar
MSFITOY
Try two holes...
Old Sep 1, 2007 | 07:06 AM
  #59
Rally@StanceDesign's Avatar
Rally@StanceDesign
You have any evidence to back up that claim?
Old Sep 1, 2007 | 07:24 AM
  #60
goaljnky's Avatar
goaljnky
Yes, I do. And all of it anecdotal and unsupported... much like everything else around here..
Old Sep 1, 2007 | 07:41 AM
  #61
mozzarella's Avatar
mozzarella
Originally Posted by MSFITOY
Try two holes...
Yep nuts .....lol
Old Sep 1, 2007 | 07:52 AM
  #62
goaljnky's Avatar
goaljnky
I think I misunderstood your post. Are you saying that even with a good portion of the hood removed the DFIC will never reach the efficiency of a stock intercooler?
Old Sep 1, 2007 | 08:08 AM
  #63
mozzarella's Avatar
mozzarella
Hasn't M7 posted the data on this?
Old Sep 1, 2007 | 08:40 AM
  #64
Rally@StanceDesign
Well they offered test results saying that even without this added mod, it was more efficient than the stock one. You stated that this is required to reach the efficiency of the stock one. I was wondering where you got this information to suggest that it performs less efficiently than the stock cooler.
Old Sep 1, 2007 | 09:04 AM
  #65
goaljnky's Avatar
goaljnky
There are a few threads around where tuners have removed the DFIC and reinstalled the stock intercooler to maximize efficiency with heads+header+etc. I think the killer was boost loss with the DFIC... this is way OT for this thread, plus I really don't want to do the search right now, nor am I an expert on the topic. I think DrObnxs has a post somewhere where he explains it all. Including why he removed the DFIC and installed the GP intercooler.
Old Sep 1, 2007 | 09:12 AM
  #66
Dr Obnxs's Avatar
Dr Obnxs
According to "the hitchikers guide to the galaxy"
Originally Posted by trackertracker
We need a Doctor Obnxs opinion on this.
At a range of ambient temperatures 70 tp 100 degrees : a range of
vehicle speeds of 40 to 100 mph ; a range of engine RPM's of 3,000 to
6,000 ; sea level 30.0 barametric pressure/ 35% relative humidity,
no wind speed; -----at what ,if any ,of the intersection of these parameters
does the rate of cooling of the M-7 DFIC with the new exit air vent
exceed the rate of cooling without the new exit air vent
(p.s.----you don't get partial credit if you say " hit it with a big stick"
as proposed in the Alta PSRS thread )
IS THERE THE DOCTOR IN THIS HOUSE
the answer is 42!
Matt
Geeze, doesn't anyone read anymore?
ps, it's an intercooler. You hit these with little sticks. Big sticks are for suspension work!
Old Sep 1, 2007 | 10:03 AM
  #67
Rally@StanceDesign
oh ok....i would have never guessed
Old Sep 1, 2007 | 10:33 AM
  #68
mozzarella's Avatar
mozzarella
Look at the hood of the Caddy ctsv racer car and you'll get the hack saw out.
Old Sep 1, 2007 | 11:56 AM
  #69
trackertracker
Dr Obnxs: I kind of thought 42, but then again 17 is one of my favorites.
So, intergrating we get dual convergence at 4,200 RPM
then again at 5,900 RPM . If this is not the case on the
Dyno, then we will go to the little stick
(PS---the only car out of the ten car Dyno day in Orlando to put harder
than TrackerTracker was a Turbo/Supercharged car)
Old Sep 1, 2007 | 04:10 PM
  #70
Dr Obnxs's Avatar
Dr Obnxs
Thinks to consider with ICs...
driving style and other goodies. I went from the DFIC to the GP cause of higher RPM work. For street driving, the DFIC is great. It's designed to have very good thermal efficiencies, and this pays off at lower speeds. But as you start to live on the track, then giving up some thermal efficiency for reduced pressure drop is worth considering. The speeds are higher, so there's more cooling air flow. But RPMs can be screaming for a good portion of the track, and ICs that have a higher drop take a hit here.
FWIW, go look up your stuff from Chemistry or Physics. Read about the ideal gas law. It's air density that you want to maximize, and this is a function of both pressure and temp. So you can have an IC with better thermal properties that works less well, or you can have an IC with worse thermal properties, that delivers more oxygen to the engine. You have to keep both pressure and temp in mind.
Matt
Old Sep 1, 2007 | 11:10 PM
  #71
///ACS330Ci's Avatar
///ACS330Ci
Randy
M7 Tuning
Thanks for the update Randy.
Old Sep 2, 2007 | 04:34 PM
  #72
maxmini's Avatar
maxmini
Originally Posted by ///ACS330Ci
LOL
Does anyone have pictures of the underside of the hood with the vent installed?
I took a quick shot of the prototype on my car for you . The way this scoop and the production piece are designed so the cut has a bit of leeway and you do not need to be 100% accurate. There is a lip molded in which will cover minor variances.
Randy
M7 Tuning
Old Sep 3, 2007 | 06:27 AM
  #73
trackertracker
Thanks for the pic Randy. What is the scoop made out of ? ( see, you KNEW
that if you gave us a little information, we would just hound you to death )
Old Sep 3, 2007 | 08:02 AM
  #74
maxmini's Avatar
maxmini
No worries that is what I am here for Mine was hand built but the production pieces will be fiber glass to my knowledge. If that is not the case I will correct myself later
Randy
M7 Tuning
Old Sep 3, 2007 | 12:09 PM
  #75
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
A new hood is around $453....:impatient
