Interior/Exterior Hood Air Extractor Scoop
Old Sep 13, 2007 | 05:36 PM
  #301
AZLarryB's Avatar
AZLarryB
plasma cutter or Sawzall ?
Just thought I'd throw out my newest smiley I got off another site:
Hope it helps the thread out.......
Old Sep 13, 2007 | 05:50 PM
  #302
maxmini's Avatar
maxmini
Love that smiley and it is VERY animated on my screen. We used a air driven skill saw to cut mine. Cut like Butta
Randy
M7 Tuning
Old Sep 13, 2007 | 06:45 PM
  #303
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by MSFITOY
Ha ha...Let me be the bad example then...
You a bad example? C'mon...
I guess I should have said, "the only one on this board with a cool, level head that jumps in the pit when the sh*t is flyin' to restore order.
Old Sep 14, 2007 | 07:12 AM
  #304
pberry51mini's Avatar
pberry51mini
No Fear Gear
So far, what is considered the best tool to cut this hole i the hood?
Particularly for the DIY guy.
I have compressed air at home and perhaps could borrow a nibbler.
I also have a basic electric jig saw.
Are people actually using or considering using a sawsall? Seems a little brutal to me and somewhat hard to control for finer work.
Paul
Old Sep 14, 2007 | 07:17 AM
  #305
MSFITOY's Avatar
MSFITOY
Paul
Hi Paul...use a nibbler but don't cut right to the exact line as it can wander a bit if not held with a tight grip...leave slight room for final sanding...you could try a disk cutter but that is only good for straight lines...
Anything with teeth could grab and shake your hood violently...potentially warping/bending/chipping paint...
Old Sep 14, 2007 | 11:03 AM
  #306
pberry51mini
No Fear Gear
Hey Sid, . . .Thanks for the good tips, I'll need them.
I can rent a nibbler, I believe, or borrow from a friend. I'm hoping this kit comes from M7 soon.
Paul
Old Sep 14, 2007 | 11:47 AM
  #307
JS's Avatar
JS
Paul
Paul,
As you have compressed air, you could try cutting with a die grinder/cut off wheel. That's how I cut my hole out. You'll have to touch up with a burr, but it works nicely.
Joel
Old Sep 14, 2007 | 05:16 PM
  #308
onasled's Avatar
onasled
Originally Posted by JS
Paul,
Joel
... agree, thats how I would do it. We call it the 'wiz wheel'.
Old Sep 14, 2007 | 08:12 PM
  #309
pberry51mini
No Fear Gear
Paul,
Joel
Cool, I'll shop for one at Harbor Freight Tools.
Old Sep 18, 2007 | 07:47 AM
  #310
trackertracker's Avatar
trackertracker
Just got my GrillCraft grill to do the AES. Hope M7 has sent
the AES
Old Sep 18, 2007 | 10:38 AM
  #311
JS's Avatar
JS
the AES
Me too.
As a side note. When working on the AES, I found some expanded AL2 mesh at the local H.D. used for gutter leaf control. I'll paint some black and epoxy it in place on mine. Not trying to match any other mesh, as some will do, but just to keep things from falling into the engine bay.
Old Sep 18, 2007 | 01:07 PM
  #312
trackertracker
Yea JS. That is the way I would have done it. But I decided to go with the
"together" approach.
My AES grill is just necessary to keep stuff out while it is parked.
Once moving the "extractor" will obviously produce thrust. Once the thrust
gets to my silver stripes and Astro Black hood middle section the color/temperature differential will cause a vortex ( anticlockwise---Northern Hemisphere) which will result in an ever increasing vaccum which will
propell the car to Mach 0.9. Oh sheet too much coffee
Old Sep 19, 2007 | 05:43 AM
  #313
JS's Avatar
JS
Darn, I never calculated in the vortex effect. But now that you mention it and I see the merit of parallel alignment, on thrust vectors, I'll have to add a front mesh to my BMS (big mouth scoop). Of course I will be very careful not to misalign the mesh orientation, less I create an opposite vortex effect, that tears away the fabric of the universe.
Old Sep 19, 2007 | 06:19 AM
  #314
trackertracker
Now you are on the correct wave length JS.
However, we are getting ever closer to a Dr. Obnoxs intervention here:impatient .
Meanwhile ,back at the ranch, I hope the M7 AES is " in the mail".
Old Sep 19, 2007 | 08:49 PM
  #315
gmir green s's Avatar
gmir green s
In the M7 photos of the green and silver hood with the AES installed, I cut out the opening with a battery operated portable saber saw with a fine tooth metal blade. I taped the area of the hood with two layers of masking tape and had no problem with chipping paint of destroyed vinyl stripes. I placed a blanket over the engine and proped the hood open with a 4 x 4 on top of the DFIC to keep the saw blade from hitting anything under the hood. If you cut slowly and are very careful you will be able to follow the pattern line exactly. This worked very well for me and I hope it helps others interested in this mod. AES install time took about ONE HOUR. A couple of photos of install in my gallery.
Old Sep 19, 2007 | 08:58 PM
  #316
JustJAY's Avatar
JustJAY
Man, I can't wait to see other's pics of this.
Old Sep 20, 2007 | 05:21 AM
  #317
trackertracker
Thanks for the info GMIR GreenS. Looks great.
Okay UPS guy---where is my M7 AES
Old Sep 20, 2007 | 01:29 PM
  #318
pberry51mini
No Fear Gear
Man, I'm glad there has been such a good response to this somewhat limited production mod. I'm hoping that it will signal M7 and others to keep dreaming, keep up the R&D, keep asking questions, and keep the R53s in mind.
There surely is a day coming when we (R53s) will be old news and mods only found in the latest JC Whitney catalog.
The interest in this thread may not add up to that many sales for M7, and perhaps then (like Wendys) they will only make them as they are ordered, so I'm willing to wait for my CF AES, just grateful they're making them.
Paul
Old Sep 20, 2007 | 01:35 PM
  #319
MSFITOY's Avatar
MSFITOY
Paul
Don't worry Paul...as long as I have my R53, you can look forward to something interesting down the road...wbk...
Old Sep 20, 2007 | 01:40 PM
  #320
JIMINNI's Avatar
JIMINNI
so you aren't going to jump ship on us and get a R56 or a Clubman .
Old Sep 20, 2007 | 01:43 PM
  #321
pberry51mini
No Fear Gear
Ultra cool.
Old Sep 20, 2007 | 02:46 PM
  #322
trackertracker
MSFITOY is one of my favorite cars on NAM. I think someone needs to start a new thread so we can vote on the best car(s). We could do it once a year with a top ten approach ( how about Dopamine, Dr Obnoxs etc.)
Yea, Mini Car of The Year. Classes : R-53 ( I don't know if they ever made a different kind------OH SHEEEET---here we go ).
M7, where is my AES. I NEED it to compete in MCoTY
Old Sep 20, 2007 | 02:52 PM
  #323
Rally@StanceDesign's Avatar
Rally@StanceDesign
( I don't know if they ever made a different kind).
Lol.....how about the r50 and r52?
Old Sep 20, 2007 | 03:08 PM
  #324
trackertracker
RallyMini, I never heard of those other kinds ( ) but I am easy
Old Sep 20, 2007 | 03:12 PM
  #325
Rally@StanceDesign
R53 = 2002-2006 Mini Cooper S
R50 = 2002-2006 Mini Cooper (non-s)
R52 = 2002-2006 Mini Cooper S and non-s Convertibles
R56 = 2007+ Mini cooper S and non-s
R55 = 2008+ Clubman Mini Cooper S and non-s
R57 = 2009+ Mini Cooper S and non-s Convertibles
