Interior/Exterior Sneak Peak...CF REAR "DIFFUSER".
Old Jul 23, 2007 | 08:49 AM
  #26
Robin Casady's Avatar
Robin Casady
While the hood scoop is not a real functional part as it was in the R53, I blocked the actual opening in the hood scoop with clear plexi so as to not allow rain in on the electrical parts on top of the engine.
The MCS is now coming with the scoop partially open. About 50% of the grid in the scoop is open on mine (built in April). While it doesn't feed a cold air intake, it allows some air in while driving, and allows heat to escape over the turbo when the engine is shut off. If I were you, I'd remove that plex.
Old Jul 23, 2007 | 09:57 PM
  #27
mini_tuners's Avatar
mini_tuners
how is the bracket setup? any possible change it can be intergrated into a r53 aero bumper?
looks freaking awsome dopamine
Old Jul 24, 2007 | 02:11 PM
  #28
DOPAMINE's Avatar
DOPAMINE
Originally Posted by 1SXE-MINI
I am sure that it may add some drag, but I did it to help fill in some of the dead space below the rear bumper cover. BTW: I also added some cool new chrome driving lights to the front and some of the mesh to the hood scoop. While the hood scoop is not a real functional part as it was in the R53, I blocked the actual opening in the hood scoop with clear plexi so as to not allow rain in on the electrical parts on top of the engine.
that looks legit!
Old Jul 24, 2007 | 03:52 PM
  #29
rattmobbins's Avatar
rattmobbins
Dude, where do you get all this mesh? I love how it looks!!!
Old Jul 25, 2007 | 05:16 AM
  #30
1SXE-MINI's Avatar
1SXE-MINI
Mesh Source
I purchased all of my grille mesh from an ebay supplier called the "grilleguy" (Scott & John) It does take some modification including removing plastic tabs to mount the mesh flat. feel free to contact me if you decide to try this mod. www.grilleguy.com
Per Hans (1SXE-MINI)
Old Jul 25, 2007 | 05:20 AM
  #31
1SXE-MINI's Avatar
1SXE-MINI
I got all of the grille mesh from an ebay supplier called the "grilleguy" www.grilleguy.com It does take quite a bit of modification including cutting off numerous plastic tabs from the factory bumpers to mount the grille mesh flat. If you are thinking about this mod feel free to contact me for more details.
Old Jul 26, 2007 | 12:28 AM
  #32
mini_tuners
maybe we should move this post to the 1st gen ext/int?
Old Jul 26, 2007 | 02:47 PM
  #33
gchurchill's Avatar
gchurchill
I wonder if they have that mesh grill for the upper grill as well? As a owner of a silver car, I would love to do the lower & upper as well as the back grill. That would be a pretty neat look!!!
Old Jul 26, 2007 | 07:35 PM
  #34
1SXE-MINI's Avatar
1SXE-MINI
All of my grille mods required quite a bit of custom fitting as the mesh comes in flat sheets and they are not cut to fit as direct replacements. I also thought about the mesh for the upper grille, but it seemed to be better to replace the upper grille with the factory chrome grille from the MC. Keep in mind that the factory chrome grille, while it fits, had to also be drilled out to give it adequate cooling for the much hotter MCS. If you have specific questions about what I had to do to complete this mod, feel free to contact me.
Old Aug 3, 2007 | 09:47 AM
  #35
skillet's Avatar
skillet
Any news?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
emulajavi
Dec 24, 2018 09:15 AM
aldito2
Nov 25, 2015 09:33 PM
Mini'mon
Aug 26, 2015 01:02 PM
