Interior/Exterior Madness IC Temp Monitor
Old May 14, 2007 | 10:28 AM
markldriskill's Avatar
markldriskill
The Madness IC Temp Monitor can display temp in, temp out, or the delta. It's pretty neat, although it is a bit on the high side as far as gauges go: $269.
Having had an opportunity to see it installed in a Madness car at AMVIV, I know the package is small, but I need to know just HOW small. I would like to mount one in a 52mm gauge "cup" (which I already have, from Craven). Yes, I know it is not round, and the Craven cup IS round -- but if the whole item is small enough, I am pretty sure I can fabricate a nice looking plate to "round out" its face.
I don't want to buy this without being sure it will fit in the cup. I have e-mailed Madness, but no response from them for over two months now, so I am giving up on that.
I am hoping that one of my fellow NAMmers might have one of these and could take measurements of four dimensions:
> Overall width of the faceplate
> C-to-C distance between the holes in the faceplate
> Largest distance (diagonal?) of the box behind the faceplate
> Depth of the box behind the faceplate
Can anyone please provide these dimensions?
Thanks.
Old May 14, 2007 | 11:03 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
Bigger is better?
If you wanted to try it, and find that it is too big. We have 60mm and new 66mm cups that may help. I would be happy to trade you a 52mm (in good condition) for a larger one if it helps you out.
Old May 14, 2007 | 11:29 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I have this kit, with 2 probes and the digital readout. The readout is made by Davtron, and I did some research on the unit and the probes with the manufacturers. The guage here: http://www.aircraftspruce.com/catalo...davtronOAT.php is the same size, just not the exact meter. But the link has all the dimension you need, I believe.
cheers,
Old May 14, 2007 | 11:30 AM
Frodo's Avatar
Frodo
FYI, it will fit. I might do the same with the center gauge pod but I may just make my own plate. If you mount it in a gauge cup you will have to round the face plate and you will have two spaces tofill above and below the gauge. You could make a new round face plate as it is held on with screws. BTW, I bought mine on ebay for $199. Let me know if you need any more info on l X w
PsychoRallye
21
Feb 17, 2019 06:08 AM
simo711
Oct 8, 2015 07:07 PM
navybsn
Oct 4, 2015 03:27 PM
fkrowland
Sep 30, 2015 10:30 AM
WhinyR53
Sep 30, 2015 07:36 AM
