How To Interior/Exterior :: Boot Stripes DIY Install With Pictures
Old Feb 25, 2008 | 05:16 PM
  #76
cabriopilot's Avatar
cabriopilot
Originally Posted by ImagoX
New boot stripes for my new MINI! Aesthetic Creations stripes, just like in the How-to. Went on easy as you please in about 30 minutes, following prep and removal of the OEM badging with dental floss...
Your boot stripe installations have inspired me to give it a shot.
I will give it my best shot(s) tomorrow after a bit of Jack Daniels to calm the nerves.
Old Mar 1, 2008 | 03:48 PM
  #77
cabriopilot
Well here's my boot stripe project.
It took me about an hour, but I was trying to make sure that I didn't mess things up.
Thanks to the guidance from this thread it was as easy as you showed me it would be.
I started by cleaning the surface of the boot.
I started on the left side so that I would have to deal with the Cooper S emblem right away.
I quickly moved to the right to align the emblem.
After both stripes were on and properly aligned, I was ready for the Cooper S emblem.
And here's the finished product.
It looks like I got the emblem on straight.
Thank you for your wisdom and guidance ImagoX.
Old Mar 3, 2008 | 03:24 AM
  #78
catseye's Avatar
catseye
Originally Posted by RonP
Question.
I replaced some hood decals on a Toyota truck I used to own. When I did this I was told to use a liquid (dish soap and warm water mixture) to lightly spray on first then lay the decal down. Doing this allowed workability with the decal to get all the bubbles and wrinkles out. After a couple of hours the mixture would dry and the decal became permanent.
Has anyone done it this way? It's been so long I don't remember exactly how I did it and what the water to soap ratio was.
I've done it both ways, and the "wet" method is definitely the only way to go IMO. you can work with the material if you need to, and you will get NO bubbles. Anyone know of a reason why not to do this? Seems like one of those things that's so obvious, there must be something I'm missing.....
Old Mar 3, 2008 | 04:08 AM
  #79
CR&PW&JB's Avatar
CR&PW&JB
Dry method is
1. Less PIA. No messing with detergent and water solution. No sticky mixture, adhevise to clean off the car when you're done.
2. Faster. I can do dry install in about 30 minutes, start to finish. No waiting for the mixture to dry before removing the protective covering.
3. Looks just as good. I've had two very tiny bubbles in my three installs and they were gone within a week without having to poke them with a pin.
I would ask the same question: Why would anyone want to mess with the soapy water doing a wet install ?? If you line them up right before you start and take the squeegee slowly up or down the stripe, there is no way you can mess it up.
Old Mar 19, 2008 | 07:23 PM
  #80
that7guy's Avatar
that7guy
This thread has eased my fears about stripping the white stripes my car came with, and adding black ones myself. Has anyone done the Bonnet or is their a separate thread for that ?
Old Mar 21, 2008 | 09:31 AM
  #81
ImagoX's Avatar
ImagoX
Nah - exact same technique for the bonnet. I've always done them dry and they came out great - just be sure to measure, measure again and then walk away then measure a third time before sticking them down. Good points to take measurements are the squirter jets, the sides of the supercharger scoop )if you have one) and the sides of the MINI emblem. then just do the exact same thing as with the boot, namely cut away half the backing material and then let the squeegee do the work. I prefer to start with the TOP part of the stripe (the side closer to the windscreen) but you can do either. Best of luck to you!
Cabriopilot - looks GREAT! Congrats!
Old Mar 30, 2008 | 07:23 PM
  #82
arizona29's Avatar
arizona29
Thanks for the great post
Old Apr 1, 2008 | 07:05 PM
  #83
minicoaster27's Avatar
minicoaster27
Thanks to everyone that added to the thread, it made me decide that I want to put the bonnet/boot stripes on myself. Which brings me to my question:
Has anyone put the bonnet stripes on themselves? If so how hard is it and what can I expect when/if I do it myself. Any help is greatly appreciated!
Old Apr 2, 2008 | 02:56 AM
  #84
CR&PW&JB's Avatar
CR&PW&JB
Yep, I have... no harder than the boot stripes, IMO. Just make sure you have them lined up perfectly before you peel off the first half of the backing. As long as you've done that, smooth sailing !
Old Apr 2, 2008 | 06:18 PM
  #85
minicoaster27
Thanks, I LOVE those stripes btw. They look amazing w/ the red trim matching the red mirrors.
Old Apr 2, 2008 | 06:22 PM
  #86
CR&PW&JB's Avatar
CR&PW&JB
Thanks... yeah, I'm really happy with the way the mods turned out. Those stripes are custom from Aesthetic Creations. The red pins are wider than the standard pinstripes.
The red is carried over to other small mods, like these door sill plates, designed by me and Mike at Aesthetic Creations. My idea, his fine tuning.
Old Apr 20, 2008 | 01:31 PM
  #87
blueyes's Avatar
blueyes
I have an 04 "s" with bonnet center white stripe any idea where I can locate one to replace. also have supercharged white on base line of car down sides. Don't see too many with this design on bonnet. Any help would be appreciated
blueyes
Old Apr 20, 2008 | 02:28 PM
  #88
CR&PW&JB's Avatar
CR&PW&JB
Try Mike at www.aestheticreations.com
And hello, neighbor... I grew up down the road from you in Gettysburg.
Old Apr 20, 2008 | 03:16 PM
  #89
cabriopilot
I didn't grow up in PA but my ex-wife did and for that I will help you with the real web address.....
www.aestheticreations.net
And I also highly recommend their work.
I did a pair of boot stripes that are just amazing and can be seen on this thread.
Old Apr 20, 2008 | 03:20 PM
  #90
CR&PW&JB's Avatar
CR&PW&JB
Well... I'm going to have to talk to Mike about that whole "dot net" thing.
I've bought a couple dozen items from him and don't know the website. That's because it's under my "Favorites" and I just click. But thanks for the assist.
Old May 8, 2008 | 08:36 AM
  #91
Malcon's Avatar
Malcon
thats really cool!
Old Jul 11, 2008 | 01:24 PM
  #92
bk13's Avatar
bk13
really cool
Old Aug 20, 2008 | 03:05 PM
  #93
XSIV SUN's Avatar
XSIV SUN
Great documentation on something I've been itching to try. I was really concerned about the hinge cut outs, so I'm relieved the come pre-cut.
Here's a strange question...has anyone thought about running a single stripe along the lower body, between the wheel wells? Is that even possible?
Old Aug 20, 2008 | 03:31 PM
  #94
cabriopilot
I think this link will answer your question.
Old Oct 23, 2008 | 03:25 PM
  #95
elevatus's Avatar
elevatus
Nice work.
Old Nov 5, 2008 | 03:46 PM
  #96
sgort2's Avatar
sgort2
flickster, where did you get the yellow center stripe?
Old Nov 20, 2008 | 08:31 PM
  #97
jrclark's Avatar
jrclark
This is really helpful. I notice you have a front plate. I just brought my car back from Wisconsin and have no front plate (I live in Ohio too). Where can I get a front plate holder?
Thanks,
JC
Old Nov 20, 2008 | 08:37 PM
  #98
jrclark's Avatar
jrclark
Front license plate
Hi Mini world,
I just bought an '06 mini-Cooper and live in Ohio, a two-license state. My Mini has no front plate holder. I've read the blogs about the "two dimples in the bumper, but there doesn't seem to be any.
I like the threaded machine screws for the rear plate. Does anyone know if there is a kit available for a front plate?
Thanks,
I'm looking forward to this new adventure.
JC
Old Nov 25, 2008 | 07:35 PM
  #99
Locust's Avatar
Locust
Front License Plate Holder
I am from Virginia with a front and rear plate and have the following on my Mini for mounting the license plate.
http://new.minimania.com/web/Item/NMX7600/InvDetail.cfm
Old Nov 27, 2008 | 06:25 AM
  #100
IzzyG's Avatar
IzzyG
Quick question regarding the vinyl install: If the edges start to peel off(from improper installation or otherwise) and won't stay on(the rest of the body is perfectly situated), is there something you can apply to make just the edges sticky again?
And what did you use to cut the vinyl? I tried using a surgical blade with scalpel handle and it was a PITA to cut, real tough
