How To Suspension :: Rear Swaybar Install How-to
Old Mar 18, 2006 | 06:20 AM
  #51
Veni_Vidi_Vici's Avatar
Veni_Vidi_Vici
Originally Posted by DiD
You can't adjust the swaybar with one of the rear wheels on the ground. Both rear wheels need to be off so you can get access to both sides and freely move the rearsway.
Definitely get yourself a set of jackstands if you are going to do this yourself do no use two jacks.
Sorry you contradict you, but it can be done. Jack up one side and just use the stand on that side. Then, with the wheel off, use the jack to raise that side of the rear suspension until all of the tension is off of the swaybar bolt. Undo it, move it to the desired setting, replace and retighten the bolt, lower the jack, replace the wheel, take the vehicle off of the jack stand. Repeat on the other side.
Old Mar 28, 2006 | 04:57 PM
  #52
Motor On's Avatar
Motor On
Could someone please update the links for the missing photos??
Old May 10, 2006 | 07:18 AM
  #53
Jdewey's Avatar
Jdewey
I have a 9/03 built 2004 MCS.
I followed these directions for installing the heavier rear bar.
I have2 comments that apply to my MCS 2004.
1) Remove BOTH rear struts.
2) The drop link does indeed use a 16 mm nut. That is not a standard size open end / box wrench (in several wrench sets I have), BUT 16 mm is 5/8 inch, which is a standard size. On the 2004 you can't hold the back of the link as it is flush, you have to use the 5mm hex internal and the 16 mm box.
Thanks for the directions. I did the job in about 2 hours. A friend who had not seen these directions used a different approach, and took 4 hours.
John
Old Jun 16, 2006 | 08:54 AM
  #54
Da Boy's Avatar
Da Boy
I am installing a REar sway on a Cabrio this weekend and will try to take some pictures, But I have not been able to find much specific advice about the diferences... if someone could help out a little I started a threead here
https://www.northamericanmotoring.co...78#post1003078
thanks in advance.
Old Jul 28, 2006 | 04:38 PM
  #55
tonester's Avatar
tonester
does installing a rear sway bar on a MCS require any altercations to the heat shield?
Old Aug 17, 2006 | 04:58 PM
  #56
CARdiac's Avatar
CARdiac
Thank you for the install instructions. I found the install to be very easy but I did have a huge oh-***** moment. When I went to bolt the subframe back up I foun it to be torqued about 1/2 an inch. I could not move it on my own and was home alone. i did find a quick fix. I supported the rear wheels (actually brakes) on jackstands (I have like 4 sets) which made it easy to realign the the subframe.
Hope this helps someone else.
Old May 7, 2007 | 01:30 PM
  #57
#20Works4me's Avatar
#20Works4me
Just installed my H&R 19"mm bar great write up no problems thanks very very much!, didn't need a second body, took about 1.5hrs!
Wow what a great mod! major increase in handling performance, does for handling what the 15% pulley does for the S engine performance mod!
Old May 7, 2007 | 02:17 PM
  #58
Beecher's Avatar
Beecher
so long as i am looking at this, and since i added a rear sway on friday, i will add this, you dont need to remove the shocks, just unbolt the tops of both, and you can swing them all the ay back, and with the sway tilted all the way up, they will clear each other.
Beecher
Old May 12, 2007 | 07:33 PM
  #59
jefeant's Avatar
jefeant
Piece of cake. Thank you, your instructions are great. It took me about 3 hrs at beers :-) pace. Thanks again, and BTW what a difference on the car after the 19 by 22mm swap.
Old Aug 12, 2007 | 05:35 PM
  #60
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Wow I just finished this today. It only took my father and I an hour! And this was our first rear sway bar install.
Old Oct 23, 2007 | 08:00 AM
  #61
Speedwing's Avatar
Speedwing
Thanks!
Great write-up. I did the entire swap in 1.5 hours. I used the three bolts out and one loose method for the sub-frame. I bolted the struts back up and pried between the strut spring and sub frame to shift it back into position on the all bolts out end. EASY! Thanks!!!!!
Old Oct 23, 2007 | 08:10 AM
  #62
agranger's Avatar
agranger
I used these instructions a year or so ago to re-install my stock bar after a bushing failed on the upgraded unit that was professionally installed for me.
After learning on my car, I helped my local club install 6 rear swaybars in one afternoon and we shot a very rough video how-to. We aren't perfect by any means and I botched several nit picky details (calling it a 16 inch socket instead of a 16mm socket), but it helps to see it all: https://www.northamericanmotoring.co...ad.php?t=71918
Old Jan 7, 2008 | 04:33 PM
  #63
RocKSalt's Avatar
RocKSalt
squeaking
How do ya stop the squeaking when it get's cold? Seems to squeak when the chassis moves from side to side.
Old Jan 8, 2008 | 08:36 AM
  #64
agranger's Avatar
agranger
There are lots of ways to work on squeaking...
1. Disassemble and grease 'em (Energy Suspension PreLube recommended by several people on-line)
2. Buy bushings and brackets with Zerk fittings so you can lube them without disassembly (I pump a squeeze or so into each bushing every time I rotate the tires (every 3-4k miles)
3. Disassemble and wrap a few layers of teflon tape around the swaybar where the bushings fit it. Grease liberaly and reassemble.
4. Spray bushing with Breakfree (a gun cleaner with teflon). I haven't tried this, but have heard of good results on my local MINI board.
Old Sep 29, 2008 | 06:38 PM
  #65
Tuckaah's Avatar
Tuckaah
sway bar creaking?
Randy,
I just had H&R Sport Springs and a new 19 mm Alta sway bar installed by a BMW garage on my 08 Cooper S. The bar is making noise at the bushings during suspension travel, so off came the bar today for more lube at the bushings. Called Alta, they couldn't offer any suggestions other than lube the bushings and drive it for awhile to see if it breaks in. Have you or anyone else experienced this noise? Thanks. Tuckaah
Old Dec 26, 2008 | 01:42 PM
  #66
derkenblosh's Avatar
derkenblosh
Fix the pictures please !
Old Dec 26, 2008 | 03:28 PM
  #67
jimz68's Avatar
jimz68
Try this link:
http://webbmotorsports.com/index.php...&id=14&catid=2
Most of them are there. The only missing ones you won't need for the install.
Jim
Old Dec 27, 2008 | 12:54 AM
  #68
derkenblosh
cool thx for the quick reply :-D
Old Mar 26, 2010 | 11:49 PM
  #69
rehgee's Avatar
rehgee
the pictures arent up anymore? can anyone put them back up for this, i just bought a mini madness 22mm rear sway
Old Jan 14, 2012 | 12:56 PM
  #70
greengobln's Avatar
greengobln
anyway we could get these photos again?
Cheers
Old Jan 15, 2012 | 09:25 AM
  #71
agranger's Avatar
agranger
Can't help with the pics, but a full video is here: http://video.google.com/videoplay?do...80665043683682#
Old Jan 15, 2012 | 01:39 PM
  #72
greengobln's Avatar
greengobln
thanks granger
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
tag1260
Aug 5, 2015 04:27 AM
