How To Carbon Build-Up Cleaning - The right way...
Old Apr 8, 2018 | 11:50 PM
  #151
fasfury's Avatar
fasfury
Thanks everyone for their help, here is the result of walnut + motul carb cleaner contact sprey. If your compressor is any less than 50litre 10bar, make sure you have a carb cleaner in your hand.
Old Apr 11, 2018 | 11:12 PM
  #152
fasfury's Avatar
fasfury
Update: This is a must to every mini! All the hidden ponnys came alive. Worth each single bit of money and time spent.
Now a question: Do we have to put 2 oil catch cans or 1 will prevent or at least hold on a while?
Old Apr 12, 2018 | 03:10 AM
  #153
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
From what I’ve seen, only one is really needed on the N14 engine - fit the catch can into the rear left side PCV hose that leads to the intake manifold.
Old Apr 12, 2018 | 07:07 AM
  #154
DneprDave's Avatar
DneprDave
Eight years ago, I blocked off the rear PCV hose and put an oil catch can on the PCV hose to the turbocharger. Now there is no way for the oil mist from the crank case to reach the backs of the intake valves and cook there. I have had no problems with this set up.
Old Aug 21, 2018 | 09:18 AM
  #155
Frixos's Avatar
Frixos
This is only necessary for Cooper S and not a Justa, is that correct?
Old Aug 21, 2018 | 11:14 AM
  #156
DneprDave's Avatar
DneprDave
That is correct.
Old Sep 5, 2018 | 09:01 AM
  #157
Gabriel MCS's Avatar
Gabriel MCS
Any reviews on the situation using WMI? Any photos with some mileage using WMI?
I'm 60k miles, using WMI last 20k miles. Idk if it's necessary.
Old Sep 5, 2018 | 05:01 PM
  #158
DneprDave's Avatar
DneprDave
What is WMI?
Old Sep 5, 2018 | 10:00 PM
  #159
LostbutFound's Avatar
LostbutFound
Originally Posted by DneprDave
What is WMI?
water meth injection
Old Sep 17, 2018 | 05:19 PM
  #160
Seaswood's Avatar
Seaswood
carbon
Any photos?
i need to do oil can next.
i have used Seafoam since engine rebuild engine runs great.
Old Dec 21, 2018 | 09:39 AM
  #161
fasfury's Avatar
fasfury
I can post some pictures with wmi kit installed 6-7k km after walnut blasting in the following weeks.
Old Jan 5, 2020 | 09:15 AM
  #162
minideucecoop's Avatar
minideucecoop
Decarb tutorial on an F series?
Is everyone doing decarbs on N14s only? I have 85k on my 2015 F56 and I'd like to do this. Am I missing the post and write up where someone did this on a gen 3?
Old Jan 5, 2020 | 12:49 PM
  #163
DneprDave's Avatar
DneprDave
Carbon build up was a problem on N14 engines. I haven't seen it mentioned on N18 and newer engines.
Old Jan 5, 2020 | 12:51 PM
  #164
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
A few people have posted about doing the N18, but have not heard of it on the BMW B engines at all. What makes you feel the need to decarbon?
Old Oct 17, 2020 | 04:09 AM
  #165
Fahd Saliegh's Avatar
Fahd Saliegh
Thanks for the detailed guide to valve cleaning. This has given me the confidence to take on the job.
Old Dec 9, 2021 | 08:38 AM
  #166
Mrs.T23's Avatar
Mrs.T23
Carbon build up... Plz help...
Originally Posted by texasmontego
Update: 4-3-13.
gawannamini has put together a good write up on cleaning the valves with the Walnut Shell Method. I created these steps before the Walnut Shell method was created. If you don't mind spending about $100, you can build your own Walnut Shell Blaster (minus the compressor). Checkout his instructions in this thread: https://www.northamericanmotoring.com...ml#post3707859
This is a How-To on Removing the Carbon Build-up, the right way.
I couldn't take it anymore with the decreased performance. My car has 60K miles on it (I bought it with 50K a year ago) and I don't think the carbon build-up has ever been removed properly. The throttle was sticking, the performance was down and it just felt like the car was struggling.
I know there's a lot of people that swear by the Seafoam method, but I've run 2 bottles through my car in 4K miles and it's done nothing. I also got taken for $250 for a dealer method (while the car was in for other service) that was only a temporary fix (a few days and a warm fuzzy feeling).
So, I decided to tackle cleaning the intake ports/valves manually myself. I wasn't going to pay the dealership $$$$ without having some way of verifying it was done right and I just don't trust them. It's my car, if I want it to last, it's my responsibility.
After reading a few posts on cleaning the valves, I didn't see where anyone had done a full writeup on the procedure. I figured I would jump in and do the writeup, so others can do the maintenance, regain the lost performance and learn a thing or two about our cars.
The result? Amazing! I feel like my car runs brand new. The build-up on my car after 60K was extreme. I couldn't get a clear picture due to the location and lack of light, but trust me when I say it was extreme. After looking at it, I wasn't surprised it was running terrible. Now, the performance is back, the throttle works perfectly and it runs much smoother. I put in the BSH Oil Catch Can after I cleaned it which will definitely help reduce the buildup in the future.
Believe me when I tell you, you can do it. It's not major surgery and only takes a Saturday. I tried to lay out the steps as detailed as possible, for the inexperienced.
If you have any questions, shoot me a PM. Enjoy!
​​​​​ So, this is my first response or anything on this forum so I hope I'm doing it right. Do, I'm working on my neighbors 83 Toyota pickup 22r & I have a super stock pcv valve in guessing is carbon build up judging from the amount I found inside the thermostat housing. Is there any thing you can recommend aside from the removing the whole intake and taking an angle grinder to it? I've done that once and its not out of my realm of Mechanics, I just don't have that time frame available.... Any advice would be greatly appreciated. Thanks in advance​​​​​​
hockeydad51
Oct 9, 2015 01:51 PM
molala
Oct 2, 2015 01:53 PM
LAcooper
Sep 22, 2015 10:03 PM
kjd186
Sep 9, 2015 10:02 AM
Ntety
Sep 2, 2015 08:39 PM
