How To Retrofitting 2005+ under tray to a pre 2005 R53
Old Aug 27, 2011 | 11:16 PM
Cavalier Cooper's Avatar
Cavalier Cooper
One of the known fail points of the R53 is the power steering fan. Its position under the car makes it prone to failure from rocks/debris getting stuck in the fan, preventing it from spinning, overheating the pump. MINI improved the fan design over the years, adding a shroud in 2004, and redesigning the under tray to include a air channel in 2005, which helps to protect the fan from debris while also improving air flow. Luckily, it is very easy to add the redesigned under tray and air channel to your pre 2005 MINI.
Here’s the parts you need. On Real OEM it says the parts are only for an automatic transmission, but don’t worry, they bolt up just fine regardless of shifting preference:
51757201784
51757201784
07146981767 (x2)
All the other clips and what not under the car transfer right over.
First, remove your original under tray. It is connected with two screws on the right and left side and three bolts under the front lip. Once off, you’ll see the fan directly behind the oil pan
Attach the air channel to the new under tray using the two c-nut clips
Attach the new under tray onto the car loosely by screwing it in on the side. You’ll see that there are no screw holes on your fan to install the channel. Using the air channel as your guide, use a sharpie to mark where you’ll need to drill holes.
Drill
The air channel comes with odd tapered screws, instead of trying to match it up, we just removed them in favor for some standard screws.
Re-attach under tray and screw on the air channel .
Voila
Total cost, about $100, install ~10 minutes. Protecting a $800 pump: priceless.
Old Jan 25, 2012 | 04:16 PM
SimTechDJ's Avatar
SimTechDJ
I have the undertray on already but not the snorkel piece... i have a temp sensor for an oil drain plug.
Does this get in the way? Is there another spot for the temp plug?
Old Feb 19, 2020 | 11:43 PM
Teabudy's Avatar
Teabudy
51757201784
51757201784
07146981767 (x2)
Drill
Voila
Not sure if youre still active...but if so, is there anyway you can send me the pictures? Seems like Photobucket isn't allowing them to fully loaded and this is exactly what I'm looking for.
Thank you!!
Old Feb 20, 2020 | 02:58 AM
JKo's Avatar
JKo
rphox2003
Dec 21, 2015 05:26 AM
trashmanbob
Jun 11, 2013 07:26 AM
Brianjager
Dec 2, 2012 07:11 PM
roaduscarnivorous
Apr 5, 2012 06:08 PM
xcoastie
R55 :: Clubman Talk (2008+)
Sep 2, 2008 06:19 PM
