How To After Market Garage Door Opener
Old Jun 17, 2011 | 08:03 AM
mjgood's Avatar
mjgood
<previously posted in General Countryman Talk>
For those that don't have the homelink mirror or a sunroof, this is a quick write up to install a garage door opener and maintain a factory look....
Youtube of the switch in operation...
http://youtu.be/V4xR1_8ydlY
The PDF is in post #17 of this thread.....
the switch I use will operate two doors, I push the switch forward for one door and backwards for the other door...
Old Jul 6, 2011 | 08:28 AM
bentyyc's Avatar
bentyyc
Thumbs up
PDF of the instructions...
https://files.me.com/mjgood/kmsy0j
Nicely done!!
Tight integration. I'm impressed. Sadly, I have a sunroof toggle in that position, but maybe I could do it elsewhere...
Old Jul 6, 2011 | 12:10 PM
Theta's Avatar
Theta
That is a very good job, indeed. You can be proud of that.
Old Jul 25, 2011 | 08:18 PM
CM51's Avatar
CM51
Wow, nice job. Looks perfect.
Old Jan 30, 2012 | 12:41 PM
Kosmo's Avatar
Kosmo
Great mod! Id like to do this mod but Im curious if theres anywhere to source the stock switch itself for a totally stock look...? Every diagram I have checked shows the overhead switch console but that is as far as it breaks it down.
Old Jan 30, 2012 | 01:33 PM
mjgood's Avatar
mjgood
I'm fairly sure you would need to order the the whole switch assembly that has the sunroof switch, as far as I know the switches themselves aren't sold separately... under the switch are rubber pressure contacts, in the past I have messed around with something similar only to find that the contacts won't work to carry current, but will only send a signal to a chip which in turn activates the circuit....
Old Jan 30, 2012 | 01:42 PM
Kosmo's Avatar
Kosmo
WMW has a used switch panel for $40 from a cabrio, I was considering giving it a shot, but it probably won't match anyway even it would work
Old Mar 1, 2012 | 10:31 AM
eggmole's Avatar
eggmole
Great job!. All my switches are taken at the top, but has anyone tried to use or know where to find a momentary switch for the lower buttons on the dash. Where the sport and fog light buttons are located. This would be the ideal spot if i can keep it looking somewhat factory.
Has anyone ever tried to order or install the factory autodimming mirror? Cost? or one of the aftermaket mirror brands? Might be hard to find one the same style or shape.
Old May 23, 2012 | 09:02 AM
bigdog100's Avatar
bigdog100
I have the middle space open for a switch, where can I order a switch with the transmitter brain? Never mind I see it on the PDF.
Old Aug 2, 2012 | 03:56 PM
Zombie_Totoro's Avatar
Zombie_Totoro
Sorry, could you repost the PDF file? For some reason it keeps sending me to iCloud and won't let me open the link.
Old Aug 3, 2012 | 05:23 AM
mjgood's Avatar
mjgood
Apple has discontinued the MobileMe site, the file is too large to attach to this site so I put it on Rapid Share.... here is the link https://rapidshare.com/files/1663732...e_Door_R60.pdf
Old Aug 3, 2012 | 09:29 AM
Zombie_Totoro
Thanks! This mod is amazing.
Old Sep 10, 2012 | 11:08 AM
Hondo1's Avatar
Hondo1
Has anyone used a device called 'Flash2Pass' integrated garage door opener? I saw it posted on MiniMania. It's a device that allows you to remotely open the garage door by flashing your bright lights twice. $99 and it claims quick and easy do-it-yourself installation.
Any comments or suggestions regarding it?
Thanks!
Old Sep 10, 2012 | 12:19 PM
aleclee's Avatar
aleclee
Thanks!
A guy with one suggested it to me in this thread.
https://www.northamericanmotoring.co...6-post253.html
Old Sep 10, 2012 | 12:27 PM
Hondo1's Avatar
Hondo1
Sounds like one happy customer. Thanks for directing me there. Going to purchase it now.
Old Jan 4, 2013 | 11:20 PM
brufree3's Avatar
brufree3
Would you be so kind as to check your Rapidshare account. The link leads to a non-exhistent file and I'm itching to hook up the switch. Thanks...
Old Jan 5, 2013 | 04:52 AM
mjgood's Avatar
mjgood
I reduced the size of the PDF to post it here... file is set for Acrobat 10 or later....
File Type: pdf
Old Jan 5, 2013 | 05:02 AM
brufree3's Avatar
brufree3
Fantastic. This is great. I really appreciate this. Thanks! I know what I'll be doing next weekend...
Old Jan 10, 2013 | 09:38 AM
threar's Avatar
threar
Very cool idea; wondering if there's somewhere in that module that you could use for power and remove the need for the battery.
Old Mar 25, 2013 | 11:57 AM
fentos's Avatar
fentos
Maybe I missed it, but is the PDF posted somewhere currently?
Old Mar 28, 2013 | 11:36 PM
jgk6502's Avatar
jgk6502
It's attached in post #17 by mjgood. Use a web browser, since the link does not show up on NAMotoring app
Old Mar 30, 2013 | 10:31 AM
fentos's Avatar
fentos
That was the problem. Thank you very much! Looking forward to reading and possibly doing this with our CM!
Old Dec 16, 2015 | 01:55 PM
kashtan's Avatar
kashtan
Is there a write-up on how to remove overhead console?
Old Dec 17, 2015 | 09:52 PM
bmwr606's Avatar
bmwr606
kashtan
goto ecstuning.com
find the "full interior LED conversion" page
scroll to bottom of page and download the installation .pdf file
it contains how to fully dismantle the overhead console ... with photos
Old Dec 18, 2015 | 05:23 AM
Here you go, thanks for the mention bmwr606
https://www.ecstuning.com/Mini-2011-.../Lighting/LED/
Then:
https://www.ecstuning.com/Mini-2011-...LED/ES2602082/
Then install DOC
http://bd8ba3c866c8cbc330ab-7b26c6f3..._Light_Kit.pdf
