How To Maintenance :: Girl's Guide to Changing Transmission Fluid
Old Mar 27, 2017 | 04:24 PM
  #76
BRITISH SD's Avatar
BRITISH SD
I changed the fluid in my 04 with Midland transmission today. The problem I have is i jacked the front up and drained about 2 quarts of transmisson oil out but can only pump about 1.2 quarts back in before it overflows from the filler hole. Any ideas why or what the best jacked up angle of the car should be?
Old Dec 18, 2017 | 04:39 AM
  #77
BRITISH SD's Avatar
BRITISH SD
The answer to my own problem was that to get all the fluid back it, it should be level. I decided to put in 2.3 quarts to give it extra lubrication, since the extra fluid that it has been riding around with to date has only helped it.
Old Dec 18, 2017 | 11:17 AM
  #78
Yes, it should be level when on a rack or on the ground as much as possible.
Aug 19, 2015 12:51 PM
Aug 19, 2015 08:28 AM
Aug 19, 2015 08:27 AM
FLYM1N1
Aug 16, 2015 01:17 PM
ludedude
Aug 10, 2015 07:16 PM
