How To Audio/Navigation :: Front/Rear Channel Swap
Old Aug 21, 2013 | 09:40 PM
  #626
d.C's Avatar
d.C
massive thanks to the op and danjreed for the illustration, literally took less than 30 minutes with just a t-20 torx driver. the hardest part for me was to put the panels back in place.
huge improvements, huge.
Old Aug 23, 2013 | 12:47 PM
  #627
svtfiveoh's Avatar
svtfiveoh
Would this work on an 03 MCS non premium sound?
Old Nov 21, 2013 | 04:54 PM
  #628
cranker625's Avatar
cranker625
I also did the swap. But haven't had a chance to take a listen yet
I drew a little diagram so I can reference it from my phone when I'm hunched over in the car.
Also included a version that is color-blind friendly
Hopefully this would prove useful for those who would like to do this swap.
Old Dec 3, 2013 | 07:58 AM
  #629
sasquatch's Avatar
sasquatch
The mods should make this diagram a sticky.
Thank you for taking the time to making this diagram.
Old Dec 7, 2013 | 07:21 AM
  #630
Austinsynthetics's Avatar
Austinsynthetics
I have read the thread, and looking forward to trying this tomorrow on my 2012 MCS, CD Boost system. In a nutshell..... disconnect the battery, take a Torx 20 and pop out eight of the connectors, replace them in the order described....and I should have a much improved sound system! Is that correct?
Thank you!
Old Dec 15, 2013 | 04:26 PM
  #631
Euson's Avatar
Euson
Hello,
I would love to do this mod, but it looks like my Mini has 24 pins instead of the 12 I have been seeing here. Is my mini a freak?
Thanks,
Old Dec 22, 2013 | 12:14 PM
  #632
Euson's Avatar
Euson
Got it- Sounds much much much better.
Thanks!
Old Jan 24, 2014 | 02:31 PM
  #633
Errant's Avatar
Errant
Silly question, but is there anyway to know if this has already been done to my car (without having to pull the trim). Like, would you be able to tell by playing with the fader settings (would the display show front being increased when it's actually rear)?
Old Jan 24, 2014 | 02:36 PM
  #634
Euson's Avatar
Euson
No silly questions, Just Silly Answers.
When you fade TO the front, does the audio GO AWAY in the front instead and play only in the back??
Old Jan 24, 2014 | 02:53 PM
  #635
SmokeM's Avatar
SmokeM
Sound coming out of the speakers are now reversed. Dial up sound in rear...sound comes out of the front. Dial up sound to the front..sound comes out the rear. It should be really easy to tell.
Old Jan 24, 2014 | 03:47 PM
  #636
Errant's Avatar
Errant
Thank you both! That's what I was thinking, and it did seem that the fade was going in the opposite direction when I tried it back when I first bought him. I'll have to check it out when he's back from the dealer.
Old Jan 26, 2014 | 10:25 PM
  #637
digipengi's Avatar
digipengi
Does anyone live in the bay area that would be willing to lend me some assistance with this mod. I tried today with the T20 method but had the worst time and gave up. Thank you all!
Old Feb 15, 2014 | 09:34 AM
  #638
Jaaay's Avatar
Jaaay
Old Feb 15, 2014 | 10:40 AM
  #639
Jaaay's Avatar
Jaaay
I think i screwed up big time. I broke off 3 tips of the connectors, once i fix the tips, how do i then get them all to line up so i can connect the clear plug with all the wires into the white connector? In hindsight, i realise i shouldn't have taken the whole of the clear plastic insert out of the white plug.
Furthermore, now the car wont lock or start even though i've connected the negative end of the battery back in. Someone please help :(
Does anyone know the part number or the name of the spade connectors?
Heres the damage:
Audio/Navigation :: Front/Rear Channel Swap-hrbhsyv.jpg
Audio/Navigation :: Front/Rear Channel Swap-mvye0xq.jpg
EDIT: Had a read though the thread fully, looks like im going to have to order some new spade/bullet connectors and get them crimped on.
Meanwhile, does anyone know if the car start if I plug the connector back in minus all the speaker wires, just connecting up the brown, white and brown/white wires?
Old Feb 17, 2014 | 05:31 AM
  #640
Yehuda's Avatar
Yehuda
Oh no! By now, you must have tried reconnecting the brown & whites -- what happened? Did you get it fixed? The thoughts of your brothers are with you.
Old Feb 17, 2014 | 02:06 PM
  #641
Jaaay's Avatar
Jaaay
I managed to get someone to solder the wires, bypassing the plug. Solved the problem, but no future channel swap for me! Ive learnt my lesson, i shall not be messing around with car electronics in the future.
Old Feb 17, 2014 | 02:09 PM
  #642
digipengi's Avatar
digipengi
I'm glad you got it fixed! I am just going to do a head unit upgrade and run a line for a small sub and be happy about it.
Old Mar 13, 2014 | 03:27 PM
  #643
Edmech's Avatar
Edmech
Cool Crazy difference!!
Wow!! What a difference. Thanks for this. Next step, amp and subwoofer!!
Old Mar 25, 2014 | 09:17 PM
  #644
hugh's Avatar
hugh
Technically Challenged
Can anyone recommend an audio shop that has done this mod? I'm located in northwestern New Jersey (I80 exit 25) but would be willing to travel to have it done.
Old Apr 1, 2014 | 04:39 PM
  #645
bit_bucket's Avatar
bit_bucket
Correct me if I am wrong or if someone has mentioned it but this mod can be done solely in software and is especially good for those running amps off of the rear channel. Thanks to gtecko for this information. You need to use a suitable cable and NCSExpert. Don't know what this is? Gtecko has an awesome thread on it in the Electronics section.
Module: 2RAD
Description: Disables 100 Hz Rear Cutoff (Caution! Over-driving your rear speakers may damage your head unit!! Only use this if you have an aftermarket DSP!!)
Change "r56_stereo" to "56_hifi" to disable cutoff.
Old Apr 8, 2014 | 10:51 AM
  #646
mavrikno13764's Avatar
mavrikno13764
First Post!
Been reading a ton and just wanted to comment that this Mod is WELL WORTH it!
First, the R56 Mini is my girlfriends and I joined this site to help her mod her car correctly.
She loves listening to music but I always felt something was lacking in her car.
Quick search led me to this, and OMG what difference the switch makes!
Took less then an hour to do and no headaches anywhere.
Tools Used:
Flat head screwdriver (to pry the two pieces of the female connector apart)
Torx 20 (Did no damage to the pins as I pushed them out, I felt Torx 14 was a bit small)
Old Jul 20, 2014 | 03:41 PM
  #647
punkgeek's Avatar
punkgeek
I think bit_bucket nailed this. For anyone reading this old thread: Just make the change in software instead...
Old Aug 6, 2014 | 07:19 AM
  #648
Tony Gregory's Avatar
Tony Gregory
Smile Cheap home made tool
Hi guys. New to this. Wanted to thank you all for a brilliant forum. Took your advice but couldn't remove the connectors with a torx bit. Scratched my head. Went shopping. Purchased an extending magnetic tip pick up tool for £1.49. Couple of dollars I guess. Cut off the magnet. Cut a slot down one side for about 10 mm using nice sharp snips. Magic! The connectors removed in under five minutes at a fraction of cost of any other tooling I've seen awesome cheap mod. Brilliant difference in sound. Thanks guys
Last edited by Tony Gregory; Aug 6, 2014 at 07:23 AM. Reason: Added and spelling corrected
Old Aug 12, 2014 | 02:36 PM
  #649
noragrets's Avatar
noragrets
I can't pull this ****ing panel off. What am I doing wrong
Old Aug 17, 2014 | 06:44 PM
  #650
fritzo's Avatar
fritzo
I just did mine today. You need to pull off the rubber trim around the bottom of the door (it just pulls off), then pull off the bottom panel under the steering wheel (again, it just pulls off), and then pull the "triangle" piece off (you get the picture).
The white connector you need is attached to a sliding lock. I think I had to slide mine up to release.
BTW- for others wondering, I could not get my pins to release from the connector, so I just cut the whole damned thing off and then attached these to the wires:
I think a bag of 10 cost me $1.39 from Radio Shack. Wrapped up the connections in tape to keep them separated and it was off and running.
As for the results, I was expecting a "Eh, I guess it's a little better" reaction. However, I got a "HOLY CRAP ***** THAT'S BETTER!" reaction instead If you're on the fence about this mod- DO IT!
