[Hawaii] DIYs for the coming months?
#51
Originally Posted by Blown-Lone-Star
can you bring your dremil to the next DIY? I want to cut out the area in my cold air intake for my strut bar.
Otherwise that would be metal to dremel down- might take awhile unless you have some tip that cuts metal well.
#53
#54
#55
I did a solo DIY today - swapped my front H&R Coilovers for Bilstein PSS9 Coilovers (will do the rears tomorrow as I only had a few hours to do it). Kind of silly (I should've known) but, while I've done many suspension changes on my own, this was the first time I used power tools (thanks so much the_beastmaster ) - OMG!, it's so much easier! Stupid me, now I know......after all these times Bryan has been telling me.
Eastsidemini stopped by to borrow my belt tensioner tool and was telling me about his stripped oil plug. I lent him my Craftsman round bolt removal sockets so I hoped they worked!
#57
Originally Posted by The_Beastmaster
With the tools and your car up on jackstands, it should have taken you about 30 minutes?
#58
Originally Posted by DaKineMINI
I hope you meant per side. I did have a slight delay as the H&R Coilovers' shock was snuggly seated and I had to rubber mallet it out. Whack-whack-whack...but everything else went smoothly. Seriously though....thanks again for the power tools.
#59
No, I meant for the entire front. That's about how long it took Gerard and me to do the fronts. However, that is with the use of a 2 post lift and air powered spring compressors. The PITA was the measuring and adjusting to get the car even.
Kimolaoha
07-05-2023 01:04 PM
thebordella
08-31-2015 01:37 PM
