No oil or water gauges?
Old 06-23-2013, 03:12 AM
enchanting_sorcress's Avatar
enchanting_sorcress
enchanting_sorcress is offline
Question No oil or water gauges?
Hey Guys, took delivery of my GP2 on Wednesday. I love love love it!!!
I do have concerns about the lack of information about the engine.
Here in Australia I have no gauge for oil temp or water temp. Is it the same with you guys? Are you concerned that you dont have access to this information and has anyone installed after market gauges?
I found this astounding for a 'track' designed car, especially when my 06 JCW had oil, water AND a boost gauge!
Any input would be great
Old 06-23-2013, 05:11 AM
CHKMINI's Avatar
CHKMINI
CHKMINI is offline
No gauges in the states either. I use a ScanGaugeII to get most of the information that I want. boost can easily be programmed into the display as well.
Old 06-23-2013, 06:32 AM
rum4's Avatar
rum4
rum4 is offline
Originally Posted by chkmini
no gauges in the states either. I use a scangaugeii to get most of the information that i want. Boost can easily be programmed into the display as well.
+1
Old 06-23-2013, 06:48 AM
ASKtheteach's Avatar
ASKtheteach
ASKtheteach is offline
+2 on the ScanGauge II
Old 06-23-2013, 11:39 AM
Minidrivr's Avatar
Minidrivr
Minidrivr is offline
Scangauge II works well. If you prefer round type multi-gauge the Aeroforce Interceptor has most of the same functions as the Scangauge II but in a round, gauge pod mountable design.
Old 06-23-2013, 03:54 PM
EHans's Avatar
EHans
EHans is offline
I agree. Even the extra gauges Mini sells in as an option are lame. Water temp is good, but lateral G's and relative torque?
THat said, I liked the way they look so I got the water gauge and lateral G gauge for mine, but I wish that 2nd one was more useful, like oil temp, oil pressure, boost, etc.
Old 06-23-2013, 04:29 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
I use a scangaugeII in my GP and have it programmed with oil temp too.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 06-26-2013, 03:31 AM
teamrodney's Avatar
teamrodney
teamrodney is offline
Is it really true that oil temp is available? I had thought it not. The three things I would like displayed are oil temp, oil pressure and coolant temp.
Old 06-26-2013, 05:23 AM
ASKtheteach
The ScanGauge II needs to be programmed in order to read oil temp. I think Way Motor Works sells them already programmed. I bought mine at Advance Auto Parts, and here is the response I got from the ScanGauge folks the other day:
We do not have oil pressure yet for MINI. In order to use the XGauges codes we currently have you will need a special program. To get the unit update with the special MINI program please send the unit into our office at:
Linear Logic LLC
Attn: MINI
2222 S Dobson Rd Ste 800
Mesa AZ 85202
Regards,
Cristina Bollinger
Repairs and Technical Support
Linear Logic
1.888.433.5664
Old 06-26-2013, 12:31 PM
CravenSpeed's Avatar
CravenSpeed
CravenSpeed is offline
Vendor
We are also getting near production on a set of OBDII driven gauges that will look like the factory tach, if that is something that interests you. First two available will be boost and engine temp. There is some more information in this thread.
Old 06-26-2013, 12:45 PM
WayMotorWorks
Vendor
Yes we sell them preprogrammed with the oil temp so you don't have to send them in.
Old 03-20-2016, 04:02 PM
32 ft. per sec2's Avatar
32 ft. per sec2
32 ft. per sec2 is offline
Does anyone make water & oil temp gauges with the dark face, so they look stock?
Old 03-20-2016, 06:19 PM
enchanting_sorcress
Ive ordered defi cr gauges to go into the craven speed flexpod. I am not going to install the bezel cover, going to leave it silver. i will post a pic once they are installed.
Old 03-20-2016, 06:49 PM
TBRoye's Avatar
TBRoye
TBRoye is offline
My biggest complaint of my wife's Clubbie no gauges and a gas gauge that is a joke.
Tom
Old 07-14-2016, 08:55 AM
Zuluracerx's Avatar
Zuluracerx
Zuluracerx is offline
get the P3. it works great, looks factory, easy install. water, oil, volts, boost, 0-60 times, ignition timing, throttle pos, intake temp. amazing.
Old 12-04-2016, 07:07 PM
32 ft. per sec2
I second that Zuluracerx, fairly easy to install and looking forward to seeing how hot the darn thing runs!
07-16-2020 12:54 PM
5904
08-27-2015 10:00 PM
Tylerlanger1
08-21-2015 03:03 PM
finn
08-21-2015 07:59 AM
dchang0
08-10-2015 03:37 PM
Quick Reply: No oil or water gauges?
