GP2 Wheel Fitment
Old Feb 1, 2016 | 12:39 PM
  #76
Manny_cooper's Avatar
Manny_cooper
Team Dynamics 1.2 17x7 e38 +5mm spacers
These will also fit.
Attached Thumbnails GP2 Wheel Fitment-12647203_10100723845186459_6976348981419519368_n.jpg
Old Feb 19, 2016 | 01:29 PM
  #77
Klenk's Avatar
Klenk
I have Enkei rpf1's on my GP.
17 x 7. ET 43. Currently using a 15mm spacer, but I will go smaller soon as the rears rub every now and then.
I did want ET 35 but couldn't find them anywhere.
This Gp is one of my favourites, love the wheels.
I believe there ssr gtv02 but I've no idea on the offset etc, so if anyone could help that would be awesome.
Probs a member on here.
Old Apr 25, 2016 | 01:21 PM
  #78
sgaffman's Avatar
sgaffman
Can anyone confirm fitment of a Weds tc005 17x7 et38 on the GP2?
Old Oct 15, 2016 | 08:00 PM
  #79
enchanting_sorcress's Avatar
enchanting_sorcress
Originally Posted by Dhorst
17" NM RSe05 in grey with Yokohoma Advan Neova AD08 R 215/45/17
No spacer, OEM nuts and caps from Way Motor Works
http://www.flickr.com/photos/mrdavid...7636448492016/
Hey Dhorst, just checked out your flicker pics. Are they the gunmetal grey?
Old Oct 16, 2016 | 06:24 AM
  #80
Johnna's Avatar
Johnna
Enchanted, Dhorst traded in his GP for a BWW and sold me the wheel and tire set. Yes, they are the gunmetal gray color.
Old Oct 21, 2016 | 06:17 PM
  #81
Zillon's Avatar
Zillon
It'll fit no problem.
I was running 17x8 +38 wheels on mine.
Old Jun 6, 2019 | 02:44 PM
  #82
Svampfest's Avatar
Svampfest
Rpf01 et35
Does rpf et35 clear front calibers on gp2 without spacers ? Can somebody confirm?
Old Jun 21, 2020 | 09:48 AM
  #83
Igor934's Avatar
Igor934
7*17 oz with 215/45 tyres
Hi to everyone.
Want to put lightweight rims for track use.
Found few photos of 7*17 OZ rims (Alleggerita and Ultraleggera) on GP2 but no info about offset.
Can anyone pls tell me what size do I need to install on GP2 with 215/45michelin cup 2 tyres without spacers and other issues? They come with ET44, ET37 and ET30..
And btw is 7 wide enough? (Stock comes in 7,5)
Thanks in advance.
Old Jun 21, 2020 | 10:11 AM
  #84
keen's Avatar
keen
Originally Posted by Igor934
215/45michelin cup 2 tyres ...
7 is plenty wide enough for 215s. 7" is the typical "measured rim width" for a 215 - if it's on a wider rim, the actual measured width will be wider than the 8.4" section width. fwiw.
you can see the specifics (tirerack is usually very good at providing the specs) - 7 to 8" width range, (you can go narrower or wider, but that's what the mfr would prefer), and measured on a 7" width.
https://www.tirerack.com/tires/tires...C2XL&tab=Sizes
Old Jun 21, 2020 | 10:19 AM
  #85
Igor934's Avatar
Igor934
Thanks a lot for a fast reply..
Any thoughts on the offset of OZ? )
Old Jun 21, 2020 | 10:21 AM
  #86
keen's Avatar
keen
it always depends on the specific wheel - the shape of the inside of the spoke area can play a large part in offset vs spacer - it's primarily the front brake caliper we're trying to clear on the GP2.
My experience with a 17x7 OZ record, ET 44, needed 6mm front spacers to clear the brake. I stacked 2 3mm to do that, and used 5mm on the rear. that made it an effective ET 38 in the front. (edited: I needed to recheck my brain. smaller positive ET == outside of the wheel further from the hub)
The stock wheel is a 7.5 ET 45 - but offset calculators are usually focused on the strut and fender lip clearance for comparisons.
this one does a pretty good job of visualizing, even if the spacer selections are crazy limited... you can add/subtract from the offset, though, to figure it out. a spacer is negative offset (moving the wheel mounting position closer to the center of the wheel, which is where 0 offset is)
https://tiresize.com/wheel-offset-calculator/
Old Jun 22, 2020 | 02:41 AM
  #87
blue al's Avatar
blue al
these are the gp2 replica calipers from Bmw performance kit
During practice fit prior to paint, oz et37 with 215/45/17 Yokohama ado8r
These are very square shouldered tyres so I expect you will be ok with others at the same spec
given The choice I would get et37 for fronts and et 44 for rears if buying new. But happily running et37 on all 4 corners
et 44 will need spacers for fronts and et30 is far too wide without “racing camber” if lowered
Et 37 oz ultraleggera
A couple of mm clearence
Old Jun 22, 2020 | 02:05 PM
  #88
smlzilla's Avatar
smlzilla
Here is mine
Hey everyone
here is my GP2 fitment. Lowered on BC racing coilovers. Wheels are fifteen52 Podium 17x7.5 35et , tires are 215/45 Pirelli Pzero
Old Jun 24, 2020 | 02:11 AM
  #89
Jimmy-R56s's Avatar
Jimmy-R56s
Originally Posted by smlzilla
Hey everyone
Really like those mate, any chance of more pictures looking down the side for an idea of fitment?
Old Jun 24, 2020 | 06:35 PM
  #90
smlzilla's Avatar
smlzilla
Old Jun 29, 2020 | 04:49 AM
  #91
Svampfest's Avatar
Svampfest
Alleggerita hlt with 205 45 17. But I'm willing to go 215 40 for next set.
Old Jul 16, 2020 | 11:32 AM
  #92
Igor934's Avatar
Igor934
Great! Just what I was looking for. Thanks.
What is the offset?
And why you aim on 215 instead of 205?
Old Jul 16, 2020 | 11:48 AM
  #93
Svampfest's Avatar
Svampfest
What is the offset?
wider wheel for less spin and its oem size
offset 37 no spacer
Old Apr 1, 2021 | 05:38 PM
  #94
mountainhorse's Avatar
mountainhorse
Necro-Bump...
Hope someone can chime in.... I really like all the input and photos !
Besides the factory GP2 Wheels... do any of the factory wheels 17" or 18" fit without spacers?
Old Apr 3, 2021 | 11:45 AM
  #95
Zillon's Avatar
Zillon
Looks great!
I have a set of these in dark gray waiting to go on my R53.
Old Apr 11, 2021 | 05:24 PM
  #96
Yoshimura 1's Avatar
Yoshimura 1
I like those fifteen 52 podium wheels.
Old Apr 19, 2022 | 05:39 PM
  #97
Nashviller56's Avatar
Nashviller56
Does RPF1 et35 clear front calibers on gp2 without spacers ? Can somebody confirm?
can somebody confirm this?
Old Apr 19, 2022 | 06:50 PM
  #98
Svampfest's Avatar
Svampfest
From what I could find, same person tried two different sets of rpf1 et35 on his gp2, one fit without spacers and other did not. Seems clearances are so little. You will probably need spacers for good measures.
Old Apr 20, 2022 | 10:40 AM
  #99
Nashviller56
i just ordered the 17x7 +35 RPF1's ill keep yall updated on how it fits
Old Apr 22, 2022 | 02:06 PM
  #100
make sure you post some pics up if they do.
