GP Rear shocks and bushings replacement
Old Apr 15, 2021 | 09:48 AM
Soul Coughing's Avatar
Soul Coughing
Hey,
I am getting around to replacing the parts on the rear suspension, but i wanted to make sure that i'm ordering the correct parts for my GP1. I am looking to replace the rear shocks with Koni Sports to complement the Sports i have in the front currently. Would i just order one for the rest of the R53 lineup? I was under the impression that i needed to find one specific for the GP due to the different rear arms? Also, what else do i need to replace while i'm in there? The bushings? Any input would be greatly appreciated.
Old Apr 15, 2021 | 12:54 PM
JackMac's Avatar
JackMac
The GP aluminum trailing arms are different from R53. Easiest option to order R53 struts and get the adaptor from Way, Helix or Orrange. Google “MINI R53 to R56 trailing arms adaptor“.
Old Apr 15, 2021 | 12:58 PM
Soul Coughing
Originally Posted by JackMac
The GP aluminum trailing arms are different from R53. Easiest option to order R53 struts and get the adaptor from Helix or Orrange. Google “MINI R53 to R56 trailing arms adaptor“.
Thanks so much! So as i have a GP, i can just order r53 rear shocks? Do you know if any of the other hardware is different? Like the swing arm bushings?
Old Apr 15, 2021 | 02:36 PM
RB-MINI's Avatar
RB-MINI
The adapters should also be available here: https://www.waymotorworks.com/wmw-re...k-spacers.html
Old Apr 15, 2021 | 04:57 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
I just finished this job a few weeks ago. All you need are the adapters from Way as noted above and the correct drill to modify the top hats since the KONI shafts are larger in diameter.
Old Apr 15, 2021 | 08:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yup they are correct just order the R53 shocks and our spacers to install them.
https://www.waymotorworks.com/koni-y...rt-shocks.html
Old Apr 20, 2021 | 09:56 AM
Soul Coughing
Ok, thanks. So basically if I wanted to be 100% original, i'd buy r56 rear shocks? And what bushings do I change in the rear suspension while im doing the rear shocks? Do people change them up or just keep stock?
Old Apr 20, 2021 | 06:19 PM
WayMotorWorks
Vendor
If you wanted to be original you would actually order GP shocks from MINI direct, but my guess is the price for them would be stupid expensive. That is why everyone goes aftermarket.
We always replace the upper rear shock mounts when we do the rear shocks with the powerflex.
https://www.waymotorworks.com/powerf...-bushings.html
Edge
Suspension
45
Sep 14, 2021 05:48 AM
Soul Coughing
GP Talk (2006)
Aug 7, 2019 11:50 AM
pglgp1292
GP Talk (2006)
Oct 6, 2015 07:56 PM
Cosmicboy
GP Talk (2006)
Jan 17, 2010 08:40 PM
