R56 rotors installed
Sep 16, 2007 | 09:05 AM
Put on the R56 rotors last night, it was an easy install and not that much money.
Sep 16, 2007 | 09:08 AM
any issues with the 14mm holes vs the 12mm bolts?
Sep 16, 2007 | 10:06 AM
R56's use 14mm bolts too!
Sep 16, 2007 | 12:53 PM
Quote:
Originally Posted by
ADAMSALTAMINI
yes, but that's not the question I asked. He's got a GP...not sure if it uses 12mm or 14mm. If it's 12mm, the rotors are for 14mm.
Sep 16, 2007 | 02:59 PM
GP's use the 14mm' but I changed to 14mm studs after needing spacers for the coilover's
Sep 17, 2007 | 01:50 PM
So, what exactly is the reason for the swap? Did you put on the drilled/slotted R56 rotors? Or are the R56s just a less expensive maintenance replacement part than the GPs?
Sep 17, 2007 | 02:55 PM
I put them on myself last weekend. I did it for the look and to help with brake fade.
Sep 17, 2007 | 02:57 PM
So, the drilled and slotted ones, eh? Cool. Bet they look sharp, too.
Sep 17, 2007 | 03:01 PM
Tomorrow LDG is fitting the brake air ducts which should work well with the new rotors
Sep 17, 2007 | 03:04 PM
garylimey
Nice!! Post pics of all this when it's done.
adrchn
Aug 13, 2019 02:11 AM
aldito2
Nov 25, 2015 09:33 PM
squawSkiBum
Oct 2, 2015 09:21 AM
thebordella
Aug 31, 2015 01:37 PM
