Engine mount help
Old Feb 12, 2023 | 12:55 PM
Ancient Mariner's Avatar
Ancient Mariner
Engine mount help
Original owner of an 02/2002 Cooper replacing engine, The right side motor mount (the part that sits in the frame- non-hydraulic) is being replaced, and the oem part that I've ordered differs from the original. Instead of threaded studs top and bottom, the replacement (and eveerything I've found -realoem, pelican parts, mini mania) only show one that has the threaded stud on top and a short internally threaded tube on the bottom, held in place by a torx head bolt up from the bottom of the frame member.
Cannot find anything matching the original- any ideas< hints, clues?
Old Feb 12, 2023 | 01:03 PM
dmath's Avatar
dmath
Is this what you're after?
https://www.fcpeuro.com/products/min...ni-22116759570
Old Feb 13, 2023 | 11:29 AM
You are talking about the older design?
https://www.realoem.com/bmw/enUS/sho...diagId=22_0066
You have to update to the newer mount
https://www.ecstuning.com/Search/Sit...h/22116759732/
Required for repair
-- Torx bolt M10X110 1
12/2003 22116759570 $2.17
-- Hex nut M12X1,5-8-ZNS3 1
12/2003 07119904578 $0.82
Jan 2, 2019 09:21 AM
LooiesMini
Dec 22, 2014 07:34 PM
yonatan11
Aug 22, 2011 09:38 PM
healey67
Jan 26, 2010 05:29 AM
auscoops
Oct 21, 2007 11:38 PM
