Relays & Switch - Shared Power Source
Old Dec 21, 2021 | 04:31 PM
JPR60's Avatar
JPR60
This is such a basic electrical question, I'm almost embarrassed to ask, but haven't found a clear answer...
I'm going to install Hella Black Magics. I'm using 10 AWG stranded copper. That is admittedly overkill. This WON'T be wired into the OEM harness, but will be on demand from a separate switch with separate wiring. So the question....
Can I "share" the power lead that will be feeding the relay (feeding #30) with the power lead that will be feeding the switch in the car? In other words, what I had planned on doing is running TWO power wires....one to the relay and one to the switch. (The switch will then have a trigger wire that runs to the relay to engage power to the lights by 'throwing' the relay open). Both would have inline fuses (15 for the relay power, 2 for the switch power).
That approach seems needlessly complex. I'd think given the size of the wire I'm using, there will basically be no issue with resistance or surge. The stock wire that Hella provides looks woefully small to me. Maybe 18 AWG. But I don't know if I'm missing something about how this works.
Anyhow, easy enough to run two power wires, separately fused, but seems silly. Can anyone with experience advise? Thanks in advance. John
Old Dec 21, 2021 | 04:47 PM
DFTR's Avatar
DFTR
Yes.
The switch is only closing a low a relay coil.
Added an electric fan to the boys truck for A/C. Did exactly that.
Old Dec 22, 2021 | 04:37 PM
JPR60's Avatar
JPR60
Awesome. Thanks so much!
Old Dec 27, 2021 | 03:05 PM
Capt_bj's Avatar
Capt_bj
concur
you CAN do that.
the purpose of the relay is to keep the full AMP load the lamps pull, away from the switch allowing use of a lower AMP feed but since the 'control' side of the relay won't pull much juice the higher feed won't hurt anything.
I've wired extra lights and air horns this way
Ken Garchow
14
Jun 3, 2019 06:29 PM
mdutton11
Mar 27, 2013 07:28 PM
DUCTTAPE
Electrical
May 24, 2011 09:41 AM
Sin MINI
Electrical
14
Jul 31, 2008 09:10 PM
aminicooper
Electrical
Aug 10, 2006 09:35 PM
