04 R50 Clutch Alignment Tool
Old Mar 12, 2020 | 01:42 PM
Chamuks's Avatar
Chamuks
Just ordered a clutch kit from mini mania
and the kit doesn’t come with the Alignment tool and are special ordered from Germany!
anyone around Santa Clarita,Ca have one that I can buy from ? Or know where I can source one?
ive called pretty much everywhere and can’t find one
Old Mar 12, 2020 | 01:47 PM
cooper48's Avatar
cooper48
Clutch alignment tools are meant to align the clutch disk and pilot bearing. Your Mini doesn't have a pilot bearing and a tool does very little to help align anything. Just make sure the disk is centered on the pressure plate when installing and you should be good to go. Turn the crank bit by bit when pushing the transmission and the input shaft should slip right in.
Old Mar 16, 2020 | 11:18 AM
We have an aftermarket ones below. https://www.ecstuning.com/Mini-2004-...etrain/Clutch/
Baum Tools which we carry has them in stock.
https://www.ecstuning.com/b-baum-too...ol/216100~btu/
Makes it easier to align the parts up so when install the main shaft rod you dont have to rock it with the transmission to wiggle it into place.
Cruztpirate
Feb 14, 2020 05:29 AM
njaremka
Sep 26, 2019 02:12 PM
Yankee
Aug 5, 2016 02:52 PM
monkeyb0y
Apr 4, 2014 09:25 AM
Carmichael
Chicago MINI Motoring Club
May 16, 2012 02:52 PM
