Bad Camshaft - 05 Cooper S Conv
Old Jul 14, 2019 | 04:19 PM
Lorie Osborne's Avatar
Lorie Osborne
2005 - Developed a missfire, cylinder 1. Plugs didn't fix it, compression checked at 0, no Compression! Pulled the head, valves are good, ended up replacing the lifter for that cylinder cause we couldn't get all 4 at the same time,,, ugh. Put it back together, still 0 compression. Pulled the valve cover again, found a piece of the cam lobe in the head. Going to change the camshaft - should we do the head as well or just the cam? Need a reputable supplier for the parts. Hoping for suggestions.
Old Jul 14, 2019 | 04:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We have several good used cams to make the fix very affordable
https://www.waymotorworks.com/used-s...0-r52-r53.html
Also check to make sure the rollers on the rockers are in good condition. If they are pitted replace them too.
rans09vert
Jun 16, 2011 08:56 PM
DreamWeaver
Jul 30, 2008 08:04 PM
MINIjr
MINIs and Minis for Sale (archive)
Jul 25, 2006 06:26 PM
MyMini05
Mar 17, 2005 09:28 PM
