Rack and pinion lube
This is amazing. I called at least 4 BMW shops, my local dealer, three steering specialist shops including the "rack and pinion doctor" and no one knows what lube to use for the rack itself. They all told me not grease it with anything. The PS fluid will take care of it. There is no PS fluid. The steering is electric. I have googled the question, looked into the Bentley maual, YouToooooobe...
What is it about tech info for this car. The dealers here don't even know where the steering units are made or by what company. Once again essential info is missing and really difficult to find.
I called the tech at Super Lube and he discussed with me the differences in lube and after listening intently decided that the super lithium moly lube I was told would work is not as good a choice as Super Lube synthetic which doesn't separate and if you are hungry after all that suspension work you can put some on your burger... It's food safe.
And there you have it. Another mystery solved after more hide and seek truth games.
DR
DR
Its a sealed unit, only the gen 1 rack/pump had CHF. Thanks for the info on the grease for the teeth/gear. I think there was an internal grease used by MINI, if I find it I will post up.
I couldn’t determine the “proper” product to use. I even called the head office of JTEKT, where the Japanese office lady answering the phone made it clear that as a civilian I had no right to ask the question. There is a ***** at the helm of every gate. I was able to chat with a tech guy at super lube. Much better experience.
What I feel is the worst part of restoring this Mini to health are the secrets that people/ companies hold so dear. I’ve only discovered some of these truths due to the kindness of people on the forums.
Thank you all.
Dan Raabe
Thank you all.
Dan Raabe
...when I rebuilt the rack on my MG Midget I just used GAA (Grease, Automotive and Artillery) like Castrol Braycote 610
If it was good enough for the recoil shocks and T and E (traverse and elevation) Hand-wheel and Crank on my M30 107mm Mortar, it is good enough for the MG.
M30
Rack and Pinion
Thanks, but is it good enough to protect from the chuk-holes in I-70?
The point here is that gen 1&2 minis are keeping a lot of businesses employed. There are specs which are not known, repair instructions left unpublished. What repair info have you researched that you cannot find? What is left out of the Bentley manual?
Your response is appreciated.
Best, Dan Raabe
Best, Dan Raabe
typing it in at my local dealer gives me the full schematic diagram:
https://parts.miniofkennesaw.com/sho...ct=10201765#--
Good stuff.
I have a feeling that the Bentley manual is pretty much an abbreviated version of the factory manual, that is usually the case with Bentley and how it was with my old Saab.
Saab had excellent factory manuals.
And also very cool quick reference parts books with diagrams which made it simple to find proper part numbers:
Although I didn't have a 79/80 (mine was an '86), I liked retrofitting some of the older components like roll-up windows and the manual steering rack from '79 EMS because it was slightly quicker ratio than the power rack.
Lovely interface with the manuals. Very legible and easy to read. Nice clear pictures.
Andrew Riley (07-23-2022)
jeffnjm3
08-03-2016 12:46 PM
