Coatings
Old Aug 25, 2018 | 09:34 AM
danraabe's Avatar
danraabe
Coatings
Has anyone rebuilt their Cooper engine and had parts coated? How do you determine if the coating is worth the investment? Does coating on bearings, camshafts, etc. wear/flake off? Who did the coatings? How much did that process cost?
Please share insights.
Thanks, DR
Old Aug 25, 2018 | 06:44 PM
downshift1's Avatar
downshift1
I've used many different coatings lately. Which coatings / parts are you considering?
Old Aug 25, 2018 | 09:38 PM
OCR's Avatar
OCR
Most help to least help.
1. Piston skirts (anti-friction)
2. Piston head (thermal)
3. Combustion chamber (thermal)
4. Sub-zero "treating" (not a coating) transmission, differential gears and shafts, axle components (anti-friction and strength)
5. Bearings (anti-friction)
No cam or valve coatings. Though some coat the chamber side of the valve heads in the thermal coatings.
Mike
Old Aug 26, 2018 | 08:28 AM
downshift1's Avatar
downshift1
1. Piston skirts (anti-friction) - Normally a Dry Film coating, works well if properly applied, works on valve stems also.
2. Piston head (thermal) - Polyphen is the most common and works well. An engineer once asked me a good question about this "Why are you trying to protect the piston from heat, you have piston squirters for that?"
3. Combustion chamber (thermal) - Same as above, works on valve faces also
4. Sub-zero "treating" (not a coating) transmission, differential gears and shafts, axle components (anti-friction and strength) - Cryo treating is cheap and easy. REM/ISF or WPC treatment for gears is better than a dry film type coating for longevity purposes. I also use ISF on timing gears to reduce friction.
5. Bearings (anti-friction) - Dry Film coating, works great.
My current head has a Ti-N coating on the rocker shafts and once I decide on a cam I will do the Dry Film on the cam journals. You could do a variety of coatings on the cam lobes but I would probably opt for a WPC treatment for longevity.
There is a lot of newer tech that can be used to help longevity and hp out there, we just need to start using it. The biggest misconception is these coatings "make hp", they don't. They reduce friction and wear that helps reduce the stress on the components in the engine.
NJP
St. Louis MINI Club
Jan 3, 2008 12:06 PM
TonyB
Aug 9, 2006 04:30 PM
jbsf3
Oct 15, 2005 09:21 PM
TonyB
Feb 18, 2005 01:18 PM
