Plastic trim maintenance
Old Aug 25, 2018 | 06:48 AM
SavannahMan's Avatar
SavannahMan
I have a new Mini and the black plastic trim around the wheel wells and under the doors already looks faded. Probably didn’t help that I tried simple green, denatured alcohol and a little gasoline to clean off some finishing sealant. Some 303 protectant makes them look better but still not great. I’d sure appreciate knowing what others are using to restore and maintain a deep black. Thanks.
Old Aug 25, 2018 | 06:53 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Here is a good thread on the matter.
https://www.northamericanmotoring.co...plastic-2.html
Old Aug 25, 2018 | 07:59 AM
cooper48's Avatar
cooper48
I use "Back to Black" on my 2004 and it works great.
Old Aug 25, 2018 | 09:59 AM
Dave.O's Avatar
Dave.O
Don’t use any high silicone based products that only last weeks and attract dirt like Black Wow or junk dressings from, Walmart, Auto-zone, Pep-Boys and all the other chain stores.
This is last years not weeks.
Gyeon TRIM
https://www.esotericcarcare.com/gyeon-q2-trim/
Old Aug 25, 2018 | 10:08 AM
NJ Mini's Avatar
NJ Mini
Do a search in the derailing forum. You’ll see many options from cleaners and dressings to dyes and coatings.
Forever black is a relatively inexpensive solution that’ll last quite a while and easy to use. The back to black will be a temporary solution but may suit your needs.
Old Aug 31, 2018 | 07:17 AM
bebevett's Avatar
bebevett
New Wipes, get it at Walmart, around $10 bucks. works good and last long.
Old Aug 31, 2018 | 02:05 PM
ammodave's Avatar
ammodave
Are you talking about this https://www.walmart.com/ip/Wipe-New-Trim-Kit/52600448 ?
Old Aug 31, 2018 | 02:08 PM
Capt_bj's Avatar
Capt_bj
technical tidbit
the trim isn't black ... it is a dark gray color ..... never was black (bought my first MINI in 2002)
if you use a black dye then .... you changed the color.
I've used Zymol since 1995 <on my Miata> ... $$ but a little goes a long way
not glossy nor does it have a 'run off' issue. Read application instructions ... works best when surface is WARM .....
https://www.zymol.com/vinyl.aspx
that's an understatement!!!!! Full strength simple green will strip paint.
the detailing gods have probably put you on a hit list ....
What you were trying to clean was probably cosmoline, used as a protective coating during shipping. Sadly the very good coverage made by MINI b4 shipping (coating interior voids) makes full removal difficult and it is not unusual to see some 'seepage' for a few months. Discussions on this go back to 2002! There are many tricks for removing without hurting the plastic trim ... like peanut butter ..... smooth, not chunky
Old Sep 1, 2018 | 01:20 PM
bebevett's Avatar
bebevett
Originally Posted by ammodave
Yes, but here in Wisconsin its $10. I have used it on a formica slate pattern countertop, that got worn from sliding thing over, looks new again. Water, and wash every day, lasted about 8 months before reapply. also daughter used it on her shutter
Old Sep 10, 2018 | 01:32 PM
Kevinp_27's Avatar
Kevinp_27
I use aerospace 303 protectant and it works great
Corey986
Apr 3, 2008 07:18 AM
CRRIKEY
19
Jan 13, 2008 07:58 AM
ImagoX
Detailing 101
11
May 18, 2007 07:43 AM
itsthedirtybird
Dec 14, 2003 11:34 AM
Dan_C
Sep 16, 2003 01:42 PM
