So I bought the Schwaben Scan Tool... Review and Q&A
Old Apr 28, 2016 | 05:44 PM
  #51
martinb's Avatar
martinb
As I recall, it's just an activate function for the pump. Haven't actually tried it yet but it's there and the folks at Schwaben assure me that it works.
As for the bleeding procedure, I'm not familiar with it. I let BR Racing do all my brake bleeds.
Old May 25, 2016 | 07:55 PM
  #52
HaveATank's Avatar
HaveATank
I just purchased this tool get it tomorrow if it doesnt clear ABS or adaptations it will be going right back. once they have all this features i will consider getting it again. If they are trying to sell something made for a MINI i think it should do everything. I own an R53 and R56 so ill see what it can and cannot do.
Old May 26, 2016 | 07:51 AM
  #53
It will clear the ABS, i just used it one Gen1 and Gen 2. The adaptation thing is for certain models, have not tested it on gen 2 automatics. It does more then read codes, you cant test functionality, which most cant do. Which is great for troubleshooting.
Also it will find stored codes and codes in the HVAC system, Footwell module, window faults etc..
Also it comes with 18 month updates for free, as more functions are added you can update.
Old Jun 4, 2016 | 03:26 PM
  #54
GeneralSpecific's Avatar
GeneralSpecific
Has anyone been successful in using the tool to reset the service intervals? I changed my oil last weekend and while it did read out the percentage remaining it would NOT reset it. I have to say I'm very disappointed!
ECS - You've got an R58 like me, have you had any luck?
Old Jun 4, 2016 | 03:51 PM
  #55
HaveATank's Avatar
HaveATank
Well it going back. It will not clear adaptations or Airbag (in my previous post input abs by mistake). For ab r53 this tools is pretty useless. Maybe better for an r56. The software on this is the same as the one on an autel which is from 2010. So dont hold your breath for them to update this for an R53.
Old Jun 5, 2016 | 04:50 PM
  #56
jamez's Avatar
jamez
Originally Posted by GeneralSpecific
Has anyone been successful in using the tool to reset the service intervals? I changed my oil last weekend and while it did read out the percentage remaining it would NOT reset it. I have to say I'm very disappointed! ECS - You've got an R58 like me, have you had any luck?
I reset the interval, but I was NOT able to CHANGE the interval on an R53 (which I would consider an advanced coding feature that I do want)
Old Jun 5, 2016 | 04:54 PM
  #57
GeneralSpecific
I'm not really bothered not being able to change the interval, I just want what I consider to be one of the most basic features... Interesting that it works for R53 and not R58.
I couldn't get it to pulse the ABS either...
Old Jun 5, 2016 | 04:55 PM
  #58
jamez's Avatar
jamez
Originally Posted by RB-MINI
Is there an actual brake bleed command/procedure to trigger the ABS pump, or do you just have to trigger the pump for each caliper at the right time? First gen, if it matters.
Yes it will trigger the ABS pump, and individual valves if you wish.
https://vimeo.com/158806259
Sorry, I haven't messed around with it enough to know the bleeding procedure yet.
Old Jun 6, 2016 | 05:00 AM
  #59
Yes, i got it to reset the airbags, reset the oil service and service intervals , and used it on both R52 and R58 models. Make sure you check out Jamez video on how to activate functions. Then let me know.
Old Oct 25, 2016 | 03:02 PM
  #60
GearheadS's Avatar
GearheadS
Mild thread resurrection! I have a 2005 MCS Convertible.
I've read the threads but am unclear on a few things:
1) Does this tool show live engine parameter data while the engine is running - things like Fuel Trim, Engine Temp, O2 Sensor Voltage, etc? If so, does it show just numbers, or will it graph them?
2) Will this tool reset the fuel trim adaptations? (I may have that term slightly wrong.)
3) Do I understand correctly that you can buy other manufacturer's modules - common ones like Toyota or Ford, for example?
4) Will it read basic OBDII codes on any OBDII car?
Thanks, Jeremy
Old Oct 25, 2016 | 03:16 PM
  #61
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I have another question: can the tool be used to turn off the "bulb out" check? (Additionally, can the tool be used as an alternative to the NCS expert software for re-coding?)
Old Oct 25, 2016 | 04:29 PM
  #62
RB-MINI's Avatar
RB-MINI
To add to the questions... will this tool display the auto trans fluid temperature on a first gen R53?
Old Oct 27, 2016 | 04:33 PM
  #63
GearheadS's Avatar
GearheadS
Hey all, still wondering the following:
5) Does it have ways to test, say, the TMAP sensor? I know it reads the code that is thrown, but does it have some active way of testing the response, resistance, or other characteristic of the sensors in order to pinpoint a bad one? (I have a P0171 error which means system lean, could be any of several things.)
Thanks!
Old Oct 28, 2016 | 05:20 PM
  #64
GeneralSpecific
Thanks!
1. Yes - all that. It can graph them.
2. I beleive so. I know that I have reset adaptations but I think it will do what you need.
3. The manufacturer does make other modules for the OEM scan tool (which ECS rebrands as Schwaben) but I can't guess as to whether you can add them. I'd call ECS and speak with them directly to confirm.
4. Yes - I've used it on my father's Ford. It can also do basic OBD type codes.
5. I don't know what a PMAP sensor is but if it reports data over the CAN bus I'd say you have a good chance of getting at that data. Specific tests are another matter - I doubt it. You're probably going to have to look up what "normal" is for the component and compare that to your car.
RB-MINI:
I think it does show auto trans temp but I don't remember.
njaremka:
No. (I wish!)
Old Dec 9, 2016 | 11:06 AM
  #65
frankthetank77's Avatar
frankthetank77
RB-MINI:
njaremka:
No. (I wish!)
I ordered one, and should be here today! I'm curious to get my codes read as my 2011 R60 has been acting up lately. Twice in the last month it's had a hard time starting and twice again it's given me half power warning while the car was struggling to run (all on separate occasions). What's infuriating about all of this is the engine, turbo, and DME are all less than a year old. Long story, but this shouldn't be happening again!
Nice write up by the way!
Old Dec 11, 2016 | 06:41 PM
  #66
GeneralSpecific
Frank, I'm gonna take a SWAG and say it's your high pressure fuel pump. Prepare your wallet... :(
Look for fuel pump related codes, and check your fuel rail pressure.
Old Dec 11, 2016 | 09:12 PM
  #67
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
HPFP is probably going to be covered so keep wallet in pocket.
Old Dec 12, 2016 | 09:58 AM
  #68
frankthetank77
Geez...I hope you're wrong. The Dealer replaced that just over a year ago...
Old Dec 12, 2016 | 07:17 PM
  #69
GeneralSpecific
I hope I'm wrong on both counts! (coverage and/or cause)
Let us know how you get on.
Old Dec 13, 2016 | 10:04 AM
  #70
frankthetank77
I do have to say you weren't far off though. While driving home last night she started to sputter and lose power. Pulled over and let her idle, and she just shut off. Luckily, I wasn't to far off from my indi and limped over and had them scan it. Came back with a bunch of low pressure fuel codes. The mechanic took it for a quick drive and said when he put a load on it the low pressure fuel reading would drop to 0...he even had a hard time getting back to the shop.
Jumped on the phone with the dealer, which is 2.5hrs south, and let them know they would be getting my car. Tow truck showed up about an hour later and off she went...
Did get a call from the dealer this morning saying they were going to get going on it soon. Now we wait!
Old Apr 18, 2017 | 01:47 AM
  #71
lajya's Avatar
lajya
a good thread... have read lots of thread about Schwaben tool and Foxwell tool
most say no difference except the shape
and i did see someone post a photo of his Schwaben tool manual and "Foxwell NT510" there
my question is Schwaben for $200 and Foxwell tool for $150... same tool with different brands? marketing tricks?
i'm considering this one http://www.eobdtool.co.uk/wholesale/...m-scanner.html
anyone has experience of this Foxwell nt510?
Old May 23, 2017 | 01:26 PM
  #72
knbond1's Avatar
knbond1
Did you end up buying this tool? Was it able to clear this adaptation for you?? I have the exact same code with mine and did the same checks. Thanks
Originally Posted by macnagaf
I need a fuel trim adaptation reset. I have a P2096 code and I have already checked for leaks in the intake tract and there was nothing. Switched my O2 sensors out for new ones and now need to reset the adaptations to get rid of the code and pass inspection by the end of March
Old May 31, 2017 | 08:29 PM
  #73
knbond1's Avatar
knbond1
Did this not clear adaptations? I want to get one for my 06' r53 to clear a fuel adaptation and have been trying to see peoples experience with it. Thanks.
Old Jun 13, 2017 | 04:14 PM
  #74
rrob311's Avatar
rrob311
05 mini cvt adaptation
Will this unit work to adapt the cvt for an 05?
Old Jun 20, 2017 | 09:15 PM
  #75
GeneralSpecific
I am not sure; I think it may. I had to do a CVT adaptation for a '03 but I used a laptop to do it.
If I remember (no guarantees) I can check my girlfriend's car this weekend to see if the option is available.
Hopefully someone else can get you an answer sooner.
