Do I have a wheel hub problem?
Old Apr 18, 2015 | 02:17 PM
LittleJoe's Avatar
LittleJoe
I am currently drive a 2006 R53 S with 140k miles. Love it.
I have recently noticed that the rear passenger tire is very loud - like a roar. It gets louder the faster I drive. I took it to the tire shop and they said the tire is fine. I even replaced the tire (I replaced all of them because they were worn) and the same loud noise persists.
The only that makes the noise go away is when I swerve sharply to the right. It goes completely away when I swerve But as soon as the weight goes back onto that tire the loud noise returns.
Do you think I can solve this problem by replacing the rear wheel hub? Seems like an easy fix, but I'm not 100-percent sure that's the problem. Also, do I need to replace wheel hubs in pairs or can I just do one?
Old Apr 18, 2015 | 03:03 PM
TVPostSound's Avatar
TVPostSound
Sounds like a bearing/hub.
Jack up that side and spin the wheel, should be noisy.
Old Apr 18, 2015 | 03:57 PM
bavmotors's Avatar
bavmotors
Definetley a bad bearing just swapped mine out today with a timkin from rock auto, get a axle nut as well. Easy one hour job.
Old Apr 18, 2015 | 04:27 PM
Capt_bj's Avatar
Capt_bj
axle nut for a rear??????
I don't think so ... OP said it was a REAR.
a standard check for a wheel bearing - in this case the entire hub - take the wheel off grab the hub at 3 and 9 o'clock and try to wiggle it. Try again at 6 and 12. Spin a couple of times and try again. If you get "wiggle" movement you need a new bearing/hub.
And swapping one side at a time is OK.
Old Apr 18, 2015 | 04:29 PM
bavmotors's Avatar
bavmotors
Originally Posted by Capt_bj
axle nut for a rear?????? I don't think so ... OP said it was a REAR. a standard check for a wheel bearing - in this case the entire hub - take the wheel off grab the hub at 3 and 9 o'clock and try to wiggle it. Try again at 6 and 12. Spin a couple of times and try again. If you get "wiggle" movement you need a new bearing/hub. And swapping one side at a time is OK.
Oops glazed over the rear part, even easier then.
Old Apr 18, 2015 | 05:43 PM
AZdsrt's Avatar
AZdsrt
140k miles? Sounds like bearing/hub to me. I'd replace both sides..
Old Apr 18, 2015 | 07:01 PM
LittleJoe's Avatar
LittleJoe
Thanks everyone. It will be my project this week.
Old Apr 18, 2015 | 08:19 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
From what your say it really sounds like a wheel bearing. We keep them in stock as we've been seeing more since these cars are getting older.
http://www.waymotorworks.com/wheel-b...0-r52-r53.html
We also offer used ones to be a cost effective option.
http://www.waymotorworks.com/used-wh...0-r52-r53.html
Old Apr 19, 2015 | 06:14 AM
bavmotors's Avatar
bavmotors
Originally Posted by WayMotorWorks
From what your say it really sounds like a wheel bearing. We keep them in stock as we've been seeing more since these cars are getting older. http://www.waymotorworks.com/wheel-b...0-r52-r53.html We also offer used ones to be a cost effective option. http://www.waymotorworks.com/used-wh...0-r52-r53.html
Just curious what brand are the cost effective hubs?
rob&JCW
Feb 13, 2023 07:03 PM
Zettinger
Aug 25, 2015 04:04 PM
ki7hy
Aug 12, 2015 07:07 PM
Aug 12, 2015 01:24 PM
