Can someone help me with speed sensitive audio setting
Old Jan 20, 2015 | 11:08 AM
MiniTech101's Avatar
MiniTech101
It's getting quite annoying .
Il be driving and regular speeds (city) then all of sudden , my volume just drops down to a ridiculous limit . Then it doesn't allow me to out it back up. I've tried my sensitivity setting at 1 and 6 and it still does It at random times .
Can I turn it off or can someone explain to me why and when it happens and how to avoid it
Old Jan 20, 2015 | 12:16 PM
pgrizard's Avatar
pgrizard
Could it be your amp is going out? If you have the HK tuned on an early gen 1 I know that is pretty common. You can also look up the pin diagram for the back of your stereo head and remove the speed sensitive volume lead.
Old Jan 21, 2015 | 02:53 AM
bmwr606's Avatar
bmwr606
you can turn it. off by setting it to 0 (zero)
i have mine set to 6 (max) and love it ... works perfect
Old Jan 21, 2015 | 05:17 AM
TBRoye's Avatar
TBRoye
How do you set or adjust it. Have 11 Justa Clubman
Tom
Old Jan 21, 2015 | 09:57 AM
bmwr606's Avatar
bmwr606
on the same screen you adjust bass treble balance etc
it is called svol i think
silence2-38554
Nov 12, 2015 09:39 AM
theblackfalcon
Oct 11, 2015 09:49 AM
MES11
Aug 8, 2015 10:21 AM
PatrikKN
Aug 5, 2015 09:10 PM
