Scangauge question
Old Jun 29, 2014 | 03:04 PM
The Patagonian's Avatar
The Patagonian
Scangauge question
Just fitted a Scangauge and everything came up straight away so no problems there however every time I start the car it reverts to the home screen........is that normal or can you set it up to always show gauges as the default?
Old Jun 29, 2014 | 03:34 PM
danjreed's Avatar
danjreed
Is to coded for Mini? Mine always reverts to the gauge presets.
Old Jun 29, 2014 | 04:16 PM
The Patagonian
Yes it is coded for MINI, I can see the five additional options (plus the sticker on the back!).
First impressions are really good but I haven't taken it on a decent run yet. I assumed it would always stay on gauges but it didn't today - if I'm lucky it will sort itself out overnight.
Old Jun 30, 2014 | 02:22 PM
The Patagonian
Left it overnight and used it 3 times today - gauge fired up perfectly every time.
I'm seeing water temp @ 104, engine & oil both reading about 214, gearbox @ 220 and max boost of 10.5 but that wasn't in the lower gears. Are they about right?
Old Jun 30, 2014 | 07:21 PM
Slave to Felines's Avatar
Slave to Felines
Yes. At least, the water and engine temps sound normal. (Water would be in C, engine in F for those to be normal I think.)
Old Jul 3, 2014 | 08:25 PM
6thGear's Avatar
6thGear
lOOKS good. I have mine to display Intake temp instead of gearbox temp.
Old Jul 6, 2014 | 02:08 PM
The Patagonian
Got a few miles on the clock now so a few comments on what I've seen so far.
Generally all temperatures run at about 220 (gearbox is about 10 degrees lower). What was surprising was that when I go to WOT the engine temps drop about 20 - I assume they would increase again if I carried on at the same rate.
During warm up oil lags water by about 30 which is normal but while most people worry about the engine coming up to temp the gearbox is at least another 30 behind.
shorenetworks
Nov 4, 2019 06:18 PM
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
