Loud pop in rear..
Old Jun 26, 2014 | 09:56 AM
JMC1's Avatar
JMC1
Loud pop in rear..
My 2010 R57 has developed a loud pop in the rear when I’m making 90 degree turns, like turning in a driveway. Thoughts?
Old Jun 26, 2014 | 12:39 PM
Grizld700's Avatar
Grizld700
Check rear sway bar links and make sure they are tight. I had something very similar happen to me about a month ago. Direction change or over a curb to a driveway there would be a loud bang in the rear. Similar to someone taking a small hammer and banging under the rear cargo area.
I replaced the rear swaybar itself 2 months prior. I must not have torqued it down well enough and after 2 months of flogging it became loose enough to move a little under stress. When the car was in the air, I was unable to move the links, but the swaybar was a little dusty and the drivers side link bolt had a halo around it where it met the swaybar, indicating there was some movement. Tightened the link bolt and I haven't had a noise since.
Could also be the link is worn out if its the original OEM style. They have a nylon cup that can give out. But if you've done any work with the sawaybar in the last 6 months to a year, I'd bet thats what you have going on.
scfiveo
Sep 27, 2019 02:27 PM
martinb
Oct 7, 2015 05:00 PM
patsum
11
Sep 30, 2015 02:20 PM
TifosinDel
Sep 28, 2015 10:45 AM
daviday
Sep 25, 2015 01:31 AM
